Question about Ricoh Office Equipment & Supplies
RICOH MP C2500 PROBLEM SERVICE CODE SC561 - Ricoh Office Equipment & Supplies
Posted by MOHAMAD YUSOF on
OfficeServiceAjnc
  • Ricoh Expert
  • 215 Answers
This is a fusing unit error. sometimes is occur by not warm up on time, and sometimes is real problem and need some part in the fusing unit to be replaced. You can try to reset it in service mode and then if machine works its ok. But if it comes again, then a visit by technician is a must. To reset the sc561 you will need to do the following procedure. First of all you need to enter into service mode. To enter into service mode you need to press the following keys on order with no rush. Press the yellow key(clear); then press the blue keypad numbers: ( 1-0-7 ) ; then press and hold for 5 seconds the red key (stop). The touch screen will change into service mode. On the touch screen press [copy sp] ; then on the blue number key pad press the following numbers: ( 5-8-1-0 ) then press the blue key { # }. On the touch screen in the right side will appear a [EXECUTE] press on it and wait to write on the screen [COMPLETED] . After it write [COMPLETED] turn off the machine by the red switch located on the middle-front of the machine left side from the first paper tray. Turn it off and wait for 10 seconds and then turn it on again. Wait for it to get ready. If it get to ready mode, everything is its okey. But if the SC561 code appear again or some similar SC code appear like SC541-542-544 etc. then a visit from a technician must me made to replace some parts in the fusing unit that are wasted.
Posted on Jun 26, 2018
5 Related Answers
Anonymous
  • 95 Answers
SOURCE: Ricoh Aficio MP C3500 Error Code SC529
It would help to know the code. Like SCxxx.
Posted on Mar 27, 2009
gggg
  • 904 Answers
SOURCE: I have a Ricoh MP C2500 Copier and I can not
Your touch screen went bad. This is a common problem with many newer Ricoh models. Get in touch with your service technician to get a new screen.
Posted on May 26, 2010
gggg
  • 904 Answers
SOURCE: Ricoh MP C2500 Error Code SC 561 what is this?
sc561 on an MP C2500 is a thermopile error. The thermopile may need to be replaced, but first make sure it is connected properly and hasn't been moved or loosened.
You'll need to go into service mode and execute SP 5810 in order to clear the sc561 code.
Posted on Jul 04, 2010
quennie732
  • 422 Answers
SOURCE: Problem with the Ricoh mp c2800 Ricoh error code
If the model ia a MPC 2800 it a controller board issue maybe the operation panel. -carl
Posted on Nov 15, 2010
Azrael SRL
  • 11800 Answers
SOURCE: My Ricoh Aficio MP C2500
The red streaks are caused by the red drum transferring way more toner than it should. Cleaning it is easy, you can do it no problem at all - all you need is a lint free rug, some pure alcohol and one hour of your time. The access is easy, no tools required and the exact procedure is in the manual.
The drum looks like that
http://www.precisionroller.com/drum-units-for-ricoh-aficio-mpc2500/products.html
The manual, if you no longer have it, can be found here
http://support.ricoh.com/bb_v1oi/html/oi/rc2/model/mpc25/mpc25en.htm
But to be honest i doubt that it will work: the drum picks so much toner because its surface has lost its sensitivity and it can't no longer generate the image correctly when struck by the laser. Most likely you will have to replace it.
Posted on Dec 17, 2010
Where can I buy new drums for Lanier MP LD425c
the problem is the model number mp ld425c
from researching you need to search on mp c2500 replacement drum
or
see
https://discountcopiercenter.com/ricoh-aficio-mp-c2500-drum-units/
suggest contacting the above company to see if lanier was taken over by ricoh
as this sometimes happens and the ricoh part may suit your printer
How to replace driver unit fan motor in ricoh aficio mp c2500
without knowing the sc code it will impossible to help because there are more than one fan in mp c2500 each one has different code and different locattion
Error code on ricoh mp c2500 error sc544 - Ricoh Aficio 2015 Copier
I have a Ricoh MP C2500 and it shows SC202 error How do I fix this
Replace your polygon mirror motor or complete laser unit if you have one available. Replace this a.s.a.p as it can cause your BICU to pop. If your machine is already dead and you picked the code up on the web browser you need to replace the BICU as well. Do not replace the BICU without replacing the polygon motor. If you do you will pop the BICU again.
How to fix error sc561 error on Ricoh Aficio Mp c2000
fuser fault code: If you are not a copier technician need to buy a new fuser assy and reset fault code through service mode or have tech come out and look at it.
I would like to know how to Fix SC561
If your copier looks anything like the smaller illustration next to the question, there most certainly should be a user's manual in the near vicinity. I'd strongly advise searching it out.
Lanier MP C2500 SC561
That is from a dirty thermistor in the fusing unit. It is the one touching the pressure roller.
2answers
12helpful
2answers
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
Bernard D'Souza
Timothy Van Der...
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
