Question about Nintendo DS Lite Console
Nintendo ds when i push power on the screen displays "error checkmenu"
Posted by baza2 on
  • Anonymous Jan 10, 2008
    when i push the on button it doesnt turn on......... the green light sometimes just blinks then it turns off again!
Laimonas Puisys
To guest. Maybe something wrong with battery. Does this problem persist when your nds is charging?
Posted on Mar 19, 2008
How to set up wifi
With an online-capable game insertedinto your Nintendo DS, turn on your system and access the game's main menu. Access the Nintendo Wi-Fi Connection settings.(These settings are typically found by selecting "Nintendo WFC" fromthe game's main menu. For detailed directions, consult the manual for thegame.) At the Setup screen, tap"Nintendo Wi-Fi Connection Settings." Tap "Connection 1 None." Clickon "Search for an Access Point." TheNintendo DS will search for any wireless networks within range. Once it isfinished searching, it will display the names of all the wireless networks itfinds. Look for your wireless network. What to do next will depend on the"lock" icon you see next to your network on the Nintendo DS. If thelock icon that appears is unlocked and blue, Select "OK," "SaveSettings," and then "Yes." The Nintendo DS will run a connectiontest with your wireless router. The connection test was successful - YourNintendo DS is now connected online and you can enjoy the Nintendo Wi-FiConnection features of the game! The connection test was not successful - Ifthe test was not successful, you will receive an error code. Error Code 51300: This means the security codeor network name entered into the Nintendo DS is not the same one the router isset to. To reach your connection settings, click "back" on the errorcode screen. Make sure to pay extra attention to the security key you find inyour router's settings and enter it exactly as it appears (the key is casesensitive). For all other error codes, go to the Nintendo website or contactcustomer support. If the lock icon is locked and red, Enter your router's WEP keyinto the Nintendo DS Select"OK," "Save Settings," and then "Yes." TheNintendo DS will run a connection test with your wireless router. Theconnection test was successful - Your Nintendo DS is now connected online andyou can enjoy the Nintendo Wi-Fi Connection features of the game! Theconnection test was not successful - If the test was not successful, you willreceive an error code. If the lock icon is locked and grey, and you wouldstill like to connect your Nintendo DS online, you will need to either changeyour router's security to WEP, or disable security entirely. Please note thatany changes you make will affect other devices that connect wirelessly to yourrouter.
Sep 17, 2011 | Nintendo Video Game Consoles & Games
Action Replay DS
Try resetting the hardware by following these steps:
1) With the console powered off, hold A+B.
2) Power up the console while still holding A+B.
3) As soon as the Nintendo screen is displayed, before our screen stating this product is not endorsed by Nintendo, press and hold Start and Select while keeping hold of A+B.
4) Continue to hold these buttons until the Main Action Replay screen is displayed, then release. Your product is reset, and will accept codes once more.
Thank you!!...
Aug 02, 2008 | Nintendo DS Lite Console
Cannot power up the DS Nintendo. The light will come on for a split second and than go off again.
I bet you have replaced a screen or opened the DS. The ribbon cables for the screens have to be securely located and ALL THE WAY into the holders otherwise the DS lights to show an error. the ribbon cable error looks like this when you power on--- Dim green for a second then bright pulse green then off.
If this is happening its a cable error RE-SEAT even if you think they are. If you get that error it is deffinately cable.
Jun 21, 2010 | Nintendo DS Lite Console
Action replay ds
1/ With the console powered off, hold A+B.
2/ Power up the console while still holding A+B.
3/ As soon as the Nintendo screen is displayed, before our screen stating this product is not endorsed by Nintendo, press and hold Start and Select while keeping hold of A+B.
4/ Continue to hold these buttons until the Main Action Replay screen is displayed, then release. Your product is reset, and will accept codes once more.
But all the codes you had before will be gone.
It looks like the day you got it.
Oct 04, 2009 | Datel Action Replay for Nintendo DS
Wont turn on
I'll quote GBATemp here:
symptom:
the ds lite powers up for a brief instant, but then shuts off
potential solution:
disassemble the lower shell and check the connections of upper and lower displays (all three flexible cable connections).
You can view the full and detailed guide here:
http://gbatemp.net/index.php?showtopic=98240
GMAC
Jun 14, 2009 | Nintendo DS Lite Console
Ds lite touch screen
have you gone to the place were you got your DS from? if you have maybe you should try sending a letter or phoning the nintendo company
Jun 18, 2008 | Nintendo DS Lite Console
Nintendo DS blinks once then off
Had this problem when reassembling my sons DS, it was the wide ribbon cable between the top and bottom screens not pushed into the connector properly, I reconnected it carefully and it powers up just fine now. Hope this helps
Dec 03, 2007 | Nintendo DS Console
Nintendo DS Lite
Are the batteries fully charged? when the first screen comes on when you first use the power switch and it says at the bottom to touch the screen. Just push the A button. If your DS still shuts off only when you touch the touch screen let us know.
Sep 03, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
35 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Ekse
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
