Question about Home Security
Lost combo to our 24 gun field and stream safe. How can I get in it.
Posted by Suzanne Rich on
Tom Chichester
    Top Expert:
  • Home Security Master
  • 61,131 Answers
Contact Field and Stream to inquire.
Posted on Nov 02, 2020
I need the preset combination for gun safe
you posted in cars and trucks, but I'll help with what I know..
Try 159#, 159*, 195#, 195*. The electronic combinations I believe reset to factory preset number which I believe is one of the 4 numbers above I just can't remember which it is.
hope this helps you.
let me know
Dec 31, 2017 | Cars & Trucks
Where can i get the factory set combo on my stack on safe
You will have to contact the manufacturer and have proof the safe is yours. No one is going to help you not even a locksmith till you can prove it is yours.
Nov 25, 2015 | Stack-On Stack On 16 Gun Safe with...
How to change combination on field& stream 10 gun safe
Guaranteed to work.....
Load Gun
Place tip of gun barrel on lock
Look away....
Pull trigger....
I'll bet the combination has changed!
Sorry... I have a sick sense of humour!
Jul 22, 2014 | Field & Stream Sportsman 10 Gun Fire Safe
I forgot my combination i tried putting a couple different numbers in after three trys the key pad locked and now when i type any numbers in it doesnt work. how do i unlock my safe?
after 3 trys the keypad does go into lockout mode but it should only last for about 15 minutes and then let you retry 3 more codes to try and open. if you still do not know what the combo is you can usually call the maker of the safe and with the serial number you might be able to get the original combo that the safe was set to when it was purchased ( this is a factory set combo ) --- now if that does not work, your next step will be to call a safe tech ( locksmith ) to set up a auto dialer,, this takes about a full 24 hours to get the combo right. the safe tech can also drill a small hole behind the dial and manually remove the locking bolt. after the safe is opened the locksmith will fill the hole and reset the combo for you ( also replace the battery at this time too ).
c...
Jan 15, 2011 | Stack-On Stack On 16 Gun Safe with...
Sentry safe model SC3877 lost original factory combo..Does anyone know it..
Each safes ships with a different factory combo. You need to contact Sentry at 1-800-282-1438 for further assistance, or follow this link to the web site
http://www.sentrysafe.com/CustomerCare/
Dec 29, 2010 | Safe International Digital Electronic Safe...
DIGITAL HOME SAFE S-25E
yes it is,,read the book that come with thi safe first, it may be an easy job, then again it may not be as some electronic saf's need to be re-programed using an e-prom setter,,,and you wont have one of them hanging around! why do you need to reset the safe? have you told some body the combo? if its a gun safe with guns inside of it,,,
some body as well as you should know the combo,,,you never know if any thing happens to you who needs to open the safe????
Jul 27, 2010 | Safe International Electronic Gun Safe...
Home Security Logo
1,086 people viewed this question
Top Home Security Experts
Marvin
Marvin
Tom Chichester
Are you a Home Security Expert? Answer questions, earn points and help others
