Question about Kenmore Microwave Ovens
My Kenmore Microwave Hood Combination model number 790.80322 is displaying error code E12. What does that mean?
Posted by Marjorie Phillips on
1helpful
I got a Kenmore microwave hood combination model number 721.80032 is it a hood fan to and how do i just turn on the hood fan
The model number 721.80032 is a partial model number; it indicates the build series. I found the Kenmore microwave, 721.80032700. The final 3 digits indicate the panel color and similar details.
Assuming the microwave was installed properly, it should work as a hood fan. Press the touch pad with the fan icon (underneath it says Hi/Low/Off) to get the desired fan speed. The icon is on the lower left of the control panel; it's below the Cook Time button and to the left of the Light button.
The manual for the 721.80032700 is available here: https://www.searspartsdirect.com/partsdirect/user-manuals/72180032700-kenmore-parts-manual?manualIndex=0 . The direct link to the Owner's Manual is https://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/L0710653.pdf . See pages 9 and 14 for using the exhaust fan.
I hope this helps.
Twice my new kenmore microwave has just started beeping with the error code E11 appearing on the screen.Have to unplug it to stop it. WHat is going on?
I think this microwave oven uses an inverter to control the power output of the magnetron. Usually the microwave will advertise this feature with a trade name like "accu-wave" or "true-power" or some similar label on the front of the microwave. Assuming that is the case here, then the E11 error means a bad inverter
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Kenmore microwave hood combination, The fan wont
With the full model number, chances are we could have helped you more.
If the cooktop lights recently failed, it may need circuit board repair.
Or it may be a failed hood TCO.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
1helpful
Microwave hood combination, model # MH9181XM, is not heating anything and displays an error code of F7
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
14helpful
4answers
Kenmore Microwave Hood Combination oven Model Service code (SE) ?
The 401 in the model number is the model prefix for Samsung, who manufactured the oven.
SE error means you have a shorted membrane keypad.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and of course one should never leave a microwave unattended while cooking.
I would need the rest of the model number from the tag to help you more.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
NOTE: The FixYa system is not currently notifying me when folks reply to my posts, so please contact me directly with your brand, model and symptoms for more FREE help & do-it-yourself advice.
Please include this URL, too:
http://www.fixya.com/support/t2931196-kenmore_microwave_hood_combination_oven
William E. Miller
[email protected]
http://www.microwavedisplay.com
Kenmore microwave model 63792 displays F2 error message
The F2 error code on your microwave oven is a membrane failure.
It is recommended that you replace the membrane first & if you still have problems to replace the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
2helpful
2answers
F7 Error code on Kenmore Ultra Wave Microwave Hood Combination Model 665.61652100
The 665 the model number prefix means it's made by Whirlpool. F7 means it has a problem with the control board or keypad.
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
If it still has a problem, we repair these for customers nationwide with our guaranteed $39.95 service. If a new keypad were needed, that would add about $60 to the repair cost.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
[email protected]
Repair or Replacement
That code means a defective sensor, and the "H" probably means it's the humidity sensor. The sensor can be replaced, but you do need to find your exact model number. It would be on a tag on the back of the oven or maybe along the door or door frame. If you or a friend want to do it yourself, you can find affordable parts here: http://tinyurl.com/gv383 Otherwise, you can call Sears service.
Microwave Ovens Logo
Top Kenmore Microwave Ovens Experts
Gerry Harvey
Gerry Harvey
Paul Carew
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
