Computers & Internet Logo
Question about LG Computers & Internet
29" LG monitor went black and won't turn back on
Posted by Donna Davis on
3 Related Answers
Mark Gough
  • 415 Answers
SOURCE: screen dead
since it's only 3weeks old as long as you have the receipt take it back .
Mark
Posted on Apr 18, 2009
budmrtn
Bud Martin
  • 11361 Answers
SOURCE: My LCD LG Flatron monitor
More likely to have failed power supply due to bad caps, that will be the first place to look.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Nov 22, 2010
Michael Baldwin
  • 51 Answers
SOURCE: LG Monitor won't turn on
I had this same problem with mine, and had to replace it. Sometimes it's the power supply, but depending on how old it is and how much it's been used, usually unlikely.
If you have a way to check the power supply output for proper current and voltage, and it appears to be fine then that's eliminated as a possibility.
Typically, time to replace it, unfortunately.
I hope this helps!
Posted on Feb 13, 2012
I hope this helps!
My LCD LG Flatron monitor decided to go black after turning off my computer. When i went to turn it back on, my computer booted, but no display on the monitor. the blue light just kept blinking. Cannot...
LG W2252TQ worked well, now black. Comes back for
Please look at my pictures: http://s807.photobucket.com/albums/yy352/budm/LG%201915S/
Common failures in ALL LCD monitors are due to failed cheaply made caps.Please look through my album so you will know what to look for (bad caps with bulging tops or leaking).
http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
2answers
LG monitor turns on for a split second and then goes black
Sorry to be the bearer of bad news but you called it, the monitor needs to be replaced.Now all we have to do is set the actual time of death...only kidding. Take care, Dana
1helpful
LG W2234S screen just went black
If you plugged power cable, and Power button on monitor is not working, something's wrong with the eletronics. Go for a refund.
LG W22h2TQ monitor just turned black
easy way to find out go to bestbuy and purchase a video card and install it if everything works out its the video card if not then its the monitor that went bad if its still under warranty send it back and get a replacement,
No picture
you should take it back
Monitor Turns Black
Try reseating the Graphics card first..It may be loose. Or try it in a different slot.
3answers
Flatron l1717s blank screen
Common cause of this is the VGA or DVI connectors not screwed on tight on either the back of the PC or the back of the monitor.
Also try removing power by unplugging for 30 seconds, sometimes that will reset things.
Top LG Computers & Internet Experts
Marvin
Marvin
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
