Question about Brookstone Office Equipment & Supplies
Do I need to download drivers for the Brookstone pocket projector? I plugged in my HDMI cable but the images are fuzzy and won't focus.
Posted by Polly Cobb on
5 Related Answers
Anonymous
  • 4 Answers
SOURCE: Picture problem
Your problem might be a simple signal issue. Make sure with your cable provider that you have adequate signal coming into the cable box to convert the signal though all those components, especially the DVI-HDMI converter. The DVI SHOULD be configured to run video only. try bypassing the audio signal with an RCA component cable. This should take the audio load off of the DVI port and re-route it through the RCA jacks, thereby supporting a better video signal. If this doesn't work, then it might be an equipment issue. The 6200 was originally designed to run on RCA component cables. Hold out till after July 1st for new CableCARD ready HD devices.
Posted on Jun 27, 2007
Anonymous
  • 563 Answers
SOURCE: ELMO Projector image not working
Hi schmidtkm
All the sympoms mentioned above is that of a faulty Mainboard that will have to be either repaired or replaced.
Trust me on this one , I work on Projectors every single day of my life.
Posted on May 13, 2008
Anonymous
  • 22 Answers
SOURCE: fuzzy images
Your projector is it in the UK if so ring me i can try to help you, i doubt it is a DLP projector (they where not very good and now largley dropped) so it may need a service or it may be an LCD fault with more info i can help you if in the UK, 0871 597 0097
Do not try to clean this yourself the high UV from these units can damage your eyesight
Marc Engineer
Posted on Jun 18, 2009
projdoc
jasbo
  • 2239 Answers
SOURCE: lose audio unless projector is on or unplugging hdmi cable from sharp xr-32x projector. works fine when watching projector
that's the way it's designed. the hdmi gives control to the projector.
Posted on Aug 19, 2009
Anonymous
  • 74 Answers
SOURCE: Thin black lines: projector TDP-ET20
Do a factory reset to the projector. In my experience that fixes alot of image problems.
Posted on Sep 26, 2009
What HDMI cable do you use for a brookstone projector
https://www.projectorcentral.com/Brookstone_hdmi_pico_projector_review.htm
Pocket Projector
Mobile includes an HDMI® compatible cable, MHL cable, 5- to 11-pin adapter and AC adapter. To connect to any device without an HDMI® compatible port, you will need an HDMI® compatible adapter or Apple Digital AV adapter (sold separately). Your device: ... Apple® iPad®, iPhone® and iPod touch® devices.
Brookstone Pocket Projector - Good Dog Digital
Projector turns on, displays Brookstone logo and then turns off. It's not the power; the unit is plugged in.
It is most likely your lamp. If you replace the lamp then you need to reset the lamp timer back to zero or it will keep shutting off on you.
There is a blue line when plugged into laptop
I had the same problem. The projector works wonderfully connected to my iPhone (with an adapter), and connected to other kinds of laptops, but not with mine. Apparently the projector is not compatible with every laptop. I had to connect my projector to my laptop via a Netgear PTV1000 streaming player in order to use it.
You connect to the player wirelessly. Then use the HDMI cable to connect the player to the projector.
Streaming Players
I happened to already have the player so I didn't have to purchase a new device. I hope this helps you.
BROOKSTONE HDMI PROJECTOR 801143 DOES NOT CHARGE
The Brookstone manual claims it will fully charge after 3-5 hours, but it takes much longer then that. Mine does not indicate green light, but it seems it stops blinking red when its fully charged. After that it run on power directly from the ac-adapter.
If you keep it connected to the AC-adapter after it have stopped blinking red (do not disconnect it at all), it will start to run on the adapter and will not turn off. You will feel the AC-adapter gets hot while its running, something it does not while regular charging.
If it still dont stop blinking red after having it connected to power for 3 days, your AC-adapter is probably faulty. This happened to me, and after allot of research I found this replacement from a US seller on ebay (only five dollars included shipping).
http://www.ebay.com/itm/251623019268?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Good luck with your projector. It a really cool little thing, but it has some design flaws.
Best regards.
Brookstone pocket projector wont turn off
i'm having the same issue. it 1st started with a No Signal error. then this started...ugh!
Hooked hdmi dongle to projector. Used kindle fire hdx. Picture works fine but no sound from projector speakers. No sound from kindle speakers. Need to use kindle headphone jack for sound.
follow this steps and fix it. God bless you
Check the system requirements on the Bluetooth dongle. If your system does not fit all the requirements, the device is not going to work. The requirements for the Bluetooth dongle are printed in the user manual and packaging. You may compare this to what is running on the computer by clicking "Start," "Control Panel" and "System." This displays the hardware running on the computer.
    • 2
Disconnect the Bluetooth dongle, restart the computer, then plug it back into a USB port. If you power on the computer with the dongle already instead, the system may not detect the equipment. Restarting the computer and performing this action helps correct the problem.
    • 3
Remove the Bluetooth dongle from the USB port and plug it into a different connection. Some USB ports fail to detect certain computer hardware. Changing the connection port fixes this.
    • 4
Install the driver on the provided driver installation CD. Without the driver, the computer is unable to detect and use the dongle. Insert the driver installation CD into the disc drive of the computer, then follow the on-screen steps to install the driver onto the system.
Hdmi pocket projector color off blue displayed as red
I bought 1 today. This evening I tried it with my camera Sony HDR250V And I noted It has the same problem You Have. How did You solve it?
Top Brookstone Office Equipment & Supplies Experts
Ekse
Are you a Brookstone Office Equipment and Supply Expert? Answer questions, earn points and help others
