Vacuums Logo
Question about Kirby Vacuums
Kirby G4, I do attach shampooer correctly, as soon as I start washing my carpet the belt slide off, why?
Posted by Hannetjie Jooste on
john h
    Top Expert:
  • Kirby Master
  • 28,843 Answers
Wrong size belt --worn loose belt or bearing at motor or pulley
Posted on Jun 20, 2018
2 Related Answers
RockyNR1
Rocky
  • 324 Answers
SOURCE: have kirby g4 carpet shampooer, need instructions for shampooer
Check out the online shampoo manual HERE
Good Luck,
Rocky
Posted on Mar 28, 2009
Anonymous
  • 174 Answers
SOURCE: I've broken two belts while using the carpet
If the belts are OEM it is probably not the problem. Be sure the brush roll very freely.
Posted on Jul 01, 2009
2answers
tip
How To Attach Carpet Shampooer To Your Kirby Generation 4 (G4) Upright.
This is an excellent, easy to follow video presentation of attaching the carpet cleaner to your Kirby Generation 3 Upright Vacuum Cleaner. Please note that the model being used in the video is a newer model named the Sentria, but the process of attaching the carpet extractor attachment is identical on the Kirby Sentria and the Kirby Generation 4. The only major difference is that the Generation 4 does not have the lever that extends out to turn the belt to off. On the Generation 4 this is dont by turning the entire white square with the Kirby logo on it in the front of the vacuum cleaner.
Please feel free to ask for a repair clarification if you have a question on how to attach the carpet shampooer. I'm always, more then happy to answer any follow up questions there may be.
Instructional Video On How To Attachment Carpet Shampooer To Kirby Generation 4 (g4) Vacuum Cleaner:
http://kirbywhq.powweb.com/videos/Carpet_Shampoo.mov
I hope that this helped you change your Kirby into a carpet shampooer. I you found this video helpful, please rate this Tip as helpful by clicking the Thumbs Up Icon. I really do appreciate it, thank you.
Chris J.
tip
How To Attach The Carpet Shampooer Cleaning Attachment Kirby Generation 3 (G3).
This is an excellent, easy to follow video presentation of attaching the carpet cleaner to your Kirby Generation 3 Upright Vacuum Cleaner. Please note that the model being used in the video is a newer model named the Sentria, but the process of attaching the carpet extractor attachment is identical on the Kirby Sentria and the Kirby Generation 3. The only major difference is that the Generation 3 does not have the lever that extends out to turn the belt to off. On the Generation 3 this is dont by turning the entire white square with the Kirby logo on it in the front of the vacuum cleaner.
Instructional Video On How To Attachment Carpet Shampooer To Kirby Generation 3 Vacuum Cleaner:
Chris J.
2helpful
How do I use shampooer?
Greetings,
If you click the link below it will take you to a video demonstration that explains step by step what you need to do to convert your Kirby into a carpet shampooer. The Vacuum in the video is the Kirby Sentria, but the procedure is the EXACT same as it is on your Kirby G3, as well as Kirby Diamond Edition, G4, G5, G6, etc. All Generation models have the same process of converting the vacuum into a carpet shampooer.
Instructional Video On How To Attach The Kirby Generation 3 Series Carpet Shampoo Attachment:
I hope that this video was helpful to you. Please feel free to request a clarification if you have any further questions about the installation, I'm always more then happy to answer any question, seriously.
If you did find this video helpful, please kindly rate my soltuion as Helpful by clicking the Thumbs Up Icon at the the bottom right hand corner of this page.
Thanks for watching!
Chris
Kirby G4 Vacuum/Shampooer
i find the kirby carpet washer is rubbish coz it leaves all the dirty water in your carpet and it goes smelly!
Kirby g2000 shampooer
Your belt is not properly connected. Here is the instructions to properly install the belt on the main power nozzle. It works exactly the same way as the shampooer head, so this should be of help...
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
Here is the instruction guide for the shampooer also. Hope this helps...
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Marci
2helpful
1helpful
Need owners manual for kirby ulitmate g series
Here is an online guide that will get you through the belt change process...you will also find manuals available. Hope this helps...
Marci
9helpful
Manual and tools kirby g4
The first link is instructions for changing a belt. The second is for the shampooer instructions. If you click on the links below, it will take you to my online guides and if you look there, your other question will be answered. Thanks!!
Marci
Top Kirby Vacuums Experts
David Shaub
Paul Bade
W.L.
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
