Question about GE Freezers
GE chest freezer FCM7DUAWW won't turn on. It periodically buzzes for a few seconds, then stops.
Posted by George Renz on
5 Related Answers
Anonymous
  • 290 Answers
SOURCE: kenmore chest freezer not working
Remove the panel covering the compressor. Remove the relay plugged on the side of the compressor and shake it. If it rattles or has any burned spots it is shorted out. Try replacing it first. Make sure you replace it with the correct replacement, not a fit-all. If this is not the problem you will need to replace the compressor. If it is less than 5 yrs old the compressor should still be in warranty. If so call Sears, it will be repaired free of charge. If it is out of warranty buy a new freezer.
Posted on Sep 25, 2007
Anonymous
  • 149 Answers
SOURCE: Compressor Stopping
compressor is running overloaded possible problems bad relay/overload /capacitor dirty or clogged condensers if the unit uses a condenser fan suspect a bad fan. and defective thermostats are notorious for short cycling. id check the coils first and if dirty clean up maybe that can be the major problem.
Posted on Apr 23, 2008
Anonymous
  • 124 Answers
SOURCE: freezer stops and start
ice cream is always the last to freeze and a temp of minus -10 degrees is usually required to get it to get hard. if you put the ice cream in the door it will be especially tough to freeze. a good thermometor is a good investment as you can observe the temps. usually ten degrees or 20 degrees is what they run. yes they do cycle on and off as long as they hold temps thats good. the outside of the freezer gets warm because the hot compressed refrigerant is spread through piping near its surface giving up its heat of compression . setting the stat to max will freeze the ice cream eventually but utility bill suffers . good luck
Posted on Nov 02, 2008
peyton32034
peyton thompson
  • 410 Answers
SOURCE: GE chest freeze won't get cold
the noise your hearing indicates the possibility of a bad start relay on the comp or possibly it just came loose during the move. on the side of the compressor you will see 2-3 wires running into an electrical connection reseat this first. if still no operation replace teh relay. you can purchase thru any reputable appliance parts dealer. after replacing the relay if you have no operation then likely problem is seized comp.
domestic freezers do not have low pressure switches that indicate low freon charge.
Posted on Jan 28, 2009
bobicehouse
Robert Moller
  • 1524 Answers
SOURCE: The compressor works for a few seconds but then stops. The freezer is over temperature.
Check the condenser fan motor (next to compressor) make sure it is running. Next change relay (inside black box) on compressor.
Posted on Apr 27, 2009
GE Freezer stopped working
Obviously, the compressor is not running. Confirm the presence of power to the compressor itself. If it is getting power and unit does not run, you have an open motor winding OR if you have a start capacitor the latter could be defective. Let's hope that you have the capacitor because they go bad and are a lot cheaper to replace than the compressor!
Jan 19, 2014 | GE 7 cu. ft. Chest Freezer FCM7DR
I have a small magic chef freezer that opens from the top. I has about 3 or 4 cu. ft. of freezer space. Lately a buzzer has been going off every 15 or 20 minutes. It buzzes for about 5-10 seconds and then...
With the time as the compressor gets old the buzzing will increased, its not a bid deal, just set the thermostat to 1 during the winter, saves you energy and give the compressor more time to rest.
Sep 28, 2011 | Magic Chef Chest Freezer MCCF5WBX
BUZZES
This sounds like the temperature monitor is alarming because the temperature has not cooled down enough yet in your freezer. turn the monitor off until the freezer reaches proper temperature then you can turn it back on.
Jul 20, 2010 | GE 14.8 cu. ft. / 419 liter Chest Freezer...
I have a chest freezer model AFFC1526DW2 it stopped freezing. The power light is still on. What could be the problem
the thermostat may not be turning on the compressor.
Do you hear a buzz and or clicking every few minutes when plugged in? If so the compressor is trying to start indicating a problem with the compressor. you could check the windings for continuity or a short and then try a 3-in-1 start kit.
May 05, 2010 | Frigidaire Freezer FFU1724
I was just given a ge chest freezer model # cb10 dk serial number vv186793. i cleaned it up and plugged it in about 5 minutes later it started buzzing . i turned the control to the lowest setting (0). and...
switch on and leave it to freeze.approx 24hours.buzzing could be compressor working overtime to get cold.or in fact the freezer is not on a level surface.
Mar 02, 2010 | GE Freezer  14.8 Cu. Ft. Manual...
My GE chest freezer quit working. When I plug it
there is a chance that your over load and starter ptc has gone bad. the worst case your compressor has gone bad.
Feb 13, 2010 | Freezers
Want to replace thermostat of ge chest freezer fcm7duaww
first of all, switch off your freezer and let all the ice to melt. now snap the capilary with a great force....... don't worry nothing will be damaged beacuse it is the only way to pull the capilary out.............have a nice day :-)
May 14, 2009 | GE Freezers
Jan 28, 2009 | GE 14.8 cu. ft. / 419 liter Chest Freezer...
Freezers Logo
280 people viewed this question
Top GE Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
John Tripp
John Tripp
Are you a GE Freezer Expert? Answer questions, earn points and help others
