Question about LG Televison & Video
How can i get my lg dvd player to work right? suddenly, when i try playing any disc, a red light blinks & i get an error message, "disc error," & the drawer opens releasing the disc.
I've checked remote, wires, discs, etc
Posted by Marilyn Baseman on
How to remove disc error message for my lg ht303su-a2 dvd cd player because it plays some dvds and other dvds wont play
Check a CD. If it plays, the Optical Pickup for the DVD is worn out and will need to be replaced.
If you are interested in having your LG repaired, please look to my website at audioserviceclinic.com. Thank you.
Dec 22, 2014 | LG HT303SU Theater System
Dvd player won't play
It sounds that the laser pickup unit of the DVD player have damaged. Check and replace it.
Jan 09, 2013 | RCA TruFlat 27F520T 27" TV
Remote Central locking
There are many types of aftermarket modules, some doing a simple lock/unlock, others also activating horns, lights, alarms, etc.
So I'd suggest searching for "how to wire car locking module," then checking out the results (including many YouTube videos).
However, you'll probably install the unit inside the driver's door panel, because that door's exterior lock and interior lock button give orders to the locks in the other three doors.
Then, use a circuit tester to identify:
--one wire that is always hot, whether the engine is on or off. This will usually be colored. This wire should be connected (use a crimp-on connector) to the power supply for your aftermarket locking module.
--a black (usually) ground wire, that should be connected to the ground wire on the module.
--one or more trigger wires running from the lock switch on the door. There are different types of trigger setups and different ways to connect them, so there may be some trial and error involved. When you've got everything hooked up, though, make sure the "lock" button on your remote makes the doors lock (and vice versa for the unlock button). If the commands are reversed, simply swap the control connections.
--if your new module also has the capability of making your horn sound and your headlights and taillights flash ... well have fun. You'll have to figure out how to hook up the wiring on the module to the headlight and taillight circuits, which won't be obvious or easy. Personally, I'd skip that part and be happy with the remote lock/unlock.
Jan 30, 2018 | 2001 Toyota Corolla Ascent
Monitor drops into sleep at random; power light amber; hard drive light green; disc drive light comes on green
Try another monitor and see if it acts the same way. Borrow a monitor from the next door neighbor for an hour or so or from a relative and see if it behaves the same way. If not, go purchase a monitor.
Apr 26, 2012 | Dell Dimension 2400 PC Desktop
I have a Vulcan Bonaire ducted heating system with Comfort Control in a holiday house, installed in 2006. It was working fine last time we used it about a month ago. Today every time I try to turn the...
hi,
The heating coil itself have some problem that's why the circuit breaker clicks off by sensing over current drop. Check the heating coil and replace it.
ok
Jun 11, 2011 | Heating & Cooling
Remote control not working
I presume you`ve checked batteies,nothing in the way etc.
The best way is to ring /email your tv company see if they have a code.
If it doesn`t work you could buy a universal remote control. read the below.
http://www.answerbag.com/articles/How-Does-a-Replacement-Remote-Control-Work/89114f3e-a2e0-b409-52ae-8384013312dc
Nov 02, 2009 | Televison & Video
LG DVB T HDD/DVD 197 won't play dvd's want error
http://www.scribd.com/doc/13204064/Lg-Dvbt-HddDvd-Recorder-Dbrh190197198199
Above is the manual for your dvd.
What we need to is eliminate first of all the discs that you can`t play etc finalised, region code.
Check through the manual.
Oct 20, 2009 | Televison & Video
LG DVD player Disc Error message even when playing lens cleaners!
LG DVD Player Disc Tray opens & closes automatically & unnecesarrily
Apr 29, 2009 | LG LXD5230 System
Televison & Video Logo
124 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
