Vijay Alone Posted on Jun 19, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sir konica minolta 206 eror in machine trouble service call c 3451 plz solve problem sir
Norman Weimar
Level 3:
  • Konica Minolta Master 7,035 Answers
  • Posted on Mar 03, 2019
Norman Weimar
Level 3:
Answers
7035
Questions
Helped
1913723
Points
11960
What model??? and that two codes ??? C-3451 and C0206?
5 Related Answers
Anonymous
  • 10 Answers
  • Posted on Jan 07, 2009
SOURCE: service manual for KONICA MINOLTA Bizhub 210/162
Swithc off the machine Press stop button and hold switch on the machine. problem will go.
Good Luck
Anonymous
  • Posted on Oct 10, 2009
SOURCE: machine trouble call service c0500
Try to power it up with the STOP button pressed.
If not call service team.
Anonymous
  • Posted on Mar 08, 2010
SOURCE: Konica Minolta Magicolor 4690MF gives 0502 error.
machine trouble 0092 service call
This happen after I cleaned the waste box for Konica Minolta Magicolor 1600W
Anonymous
  • Posted on May 11, 2010
SOURCE: how do i fix the error message MACHINE TROUBLE
1. Main switch is tuned ON.
2. Press the following keys in this order
2 -> 6 -> 2 -> 7 ->3
3. Main switch is tuned OFF/ON
hamzaskilltd
amir hamza
  • 318 Answers
  • Posted on Aug 07, 2010
SOURCE: Solution for error code c2557 konica minolta bizhub 250 machine
ADTC sensor failure
Error code CO3FF in konica minolta 215 pls help me to solve it
Enter service mode go to adjust, select correct machine 23/21/19 pages per! some one chg this setting one part of the machine thinks it one speed the other a different speed
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Sir konica minolta 206 eror in machine trouble service call c 2558 plz solve problm sir process full detail
Abnormally high T/C ratio
- The T/C ratios detected by the TCR sensor board (TCRSB) are above the threshold for the detection of abnormally high T/C ratio for three successive times.
- The connector between TCRSB to PRCC is disconnected
1 Check to see if developer is available. 2 Check the connector between TCRSBrelay CN14-PRCB CN10 for proper connection and correct as necessary. 3 Change TCRSB. 4 Execute "TCR AUTO ADJUST. 5 Change PRCB
I have a proplem in konica minolta bizhub c352 how to sort the problem i have an error code 3451
If the code comes back do not reset, you are messing with the Fuser the Hot part. Continuing to reset without a technician looking at and or replacing it, the fuser can catch on fire and that would ruin a perfectly good day. ENSURE YOU WAIT THE 10 SECONDS
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Bizhub c352 error 3451
Dear sir i have konica minolta bizhub c450 it shows enter serial no call service engineer how can i fix this problem ? thank you
When this message "Call Service Engineer" appears, then there is also trouble code along with it.You have to just note down the error code, then tell again.It will help to solve your problem.
HOW do i solve error code 3451 in konika monolta bizhub 165
switch on the machine pressing Stop switch and wait for 5 second then leave the stop switch. It happens due to low voltage. use stabilizer in your machine. If it does not solve the problem then check the heater bush of fuser unit which has been damaged.
2answers
Konica 1216
replace the developer and the drum and have the tech clean all around the drum area and the sensors
Eror code
sorry i am not familiar with error codes.
I am more for user support.
1helpful
4answers
Konica minolta bizhub 162 photocopier paper jam problem
tenho um problema de paper ja open 1st side cover,m o que fazer
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
