SOURCE: ruud heat pump capacitor size
A hard start or turbo 2000 will not work if the run capacitor is bad. You will need to contact a ruud supply house or dealer with model and serial to find out the exact match. I have checked my sources and came up empty handed. You could try getting a 35/5 MFD at 440V or a 45/5 MFD at 440V as these are the most common capacitors used in Rheem and Ruud equipment. The key is that you will need to check your amp draws on both motors against the nameplate rating to make sure that you are not over-amping the motor. Also check the nameplates on both of the motors. Most condenser fan motors and some compressors list the capacitor size they require in a somewhat less than conspicious location on the label.
SOURCE: What wire size do I run for a 3 1/2 ton AC unit?
it depends on the distance from main power source # 8 if more than 40 feet look at starting amps then google a wire sizing voltage droop chart
SOURCE: odour from ac
There is a problem with heat pumps known as "Dirty Sock Snydrome". Research this on the web as this may be your situation. It is a smell produced by micro bacterial growth on indoor coil. Contact a local HVAC company for solutions if you determine this is the cause of odor.
SOURCE: my LG intelloair 1.5 ton split a/c's compressor not working.
check the compressor's start/run capacitor. if it is swelled at the top, where the connectors are, replace it.
