Question about Sony Office Equipment & Supplies
I have a Sony snap lab cr 20l ....I have a message in the screen saying print quantity of current order exceeds maximum how can I get my printer back working
Posted by Julius Britton on
5 Related Answers
Anonymous
SOURCE: printer error
The printer is probably damaged, so, call Sony tech at 1-800-883-6817 x21 . If they will not be able to trouble shoot the problem, they will direct you to the repair facility. You have 1 year warranty on this printer if purchased from an authorized Sony dealer.
Jacob
www.kobis.com
Posted on Nov 10, 2008
Lenny L
SOURCE: My printer is not printing
After multiple trys I finaly got it to work by doing the following:
Turned off printer, disconnected network cable and power cable. and reconnecting Network cable, power cord and turning on. This was done about 5 times or more before it worked.
Posted on Mar 20, 2009
Anonymous
  • 10 Answers
SOURCE: says exceeded maximum file size when try to send
are you recording in the .3gp mode or .mp4? some phones hav these options as low/high quality...try recording in .3gp..this should work..
Posted on Aug 22, 2009
Anonymous
SOURCE: Error when printer is turned on
let me know what happened cuz I am having the same problem.
Posted on Feb 13, 2010
Rinoo Kumari
  • 2973 Answers
SOURCE: I have a sony snap lab UP-CR10L and it work and
It seems to be a driver problem which crops now and then and not a regular one. Please uninstall and reinstall the drivers as per the link below:
http://www.fixya.com/support/r3559995-installing_devices_on_pcs_and_laptops
Posted on Oct 24, 2010
HP C7180 has message INK Thresholds Exceeded Do Not ship in its current condition
Sad to say I know how to fix this.
1. Power up the printer
2. set printer's date to the current day.
3. On the keypad press the * and # keys together
Now press one at a time 1,2,3 for the code
"screen stould display a white backround with 2 lines of info"
4. remove all the print cartridges
5. Press the >> arrow button twice until "reset menu" is found
6. Press OK
7. Select Partially full reset Press ok
( the printer will take almost to minutes before it powers down)
8. Power up the printer and follow the steps.
reinstall ink ect......
I don't know why this happens but I sure a lot of printers are in the trash because of this. If you print out a SELF TEST REPORT the
dates on the age of the ink Cartridges are likely out of life range.
Planned obsolescence by HP can be found all over the web. This could be one of those.
HP Photosmart 3000 C6100 C7200 PSC 7280 Printers HP 02 Cartridge...
Press the helpfull Thanks!!!!
Jul 06, 2012 | HP Photosmart C7180 All-In-One InkJet...
CAN THE SNAP LAB DO CHRISTMAS CARDS (SLIM LINE) 4 X 8?
Yes, but you will need to upgrade the printer's version to the latest version. Go to http://www.kobisonline.com/Sony-SnapLab-UPCR10L-Snap-Lab-Digital-Photo-Printer-UP-CR10L_p_9.html for the firmware upgrade link
Dec 08, 2010 | Sony SnapLab UP-CR10L Digital Photo...
MY SONY SNAP LAB will not power up. I changed the
Sounds like your SnapLab's power supply is dead. You will have to send to repair, or order the part and replace yourself (if you think you are qualified to do that yourself...)
May 06, 2010 | Sony SnapLab UP-CR10L Digital Photo...
How to make date etc appear on back of photos
The date usually only appears on the front. However, most retail photo labs (i.e. walmart) can add custom backprinting to your photos. You can usually only add one line of text for entire order and custom pricing would probably make this a little bit expensive. On that note, the date you have your film developed/printed is usually printed on the back of each print for free, as this is default setting for the lab's printer.
Feb 17, 2010 | Pentax Photography
Unable to Change 50 message on Brother won't go away
reset your printer, you exceed the maximum printing limit. just reset it by downloading res-setter on the web
Jan 15, 2010 | Brother Multi-Function Center MFC-240C...
After a ps print job is sent and printed by the
There is probably nothing wrong with the printer, but it may not be be receiving all the dope it needs. Usually the printer needs a CR/LF signal at the end of the file to print. If it doesn't get that it will assume that it hasn't got all the file and will hang. This may be a setting in the application producing the file, or a setting on the printer itself (i.e needing either a full CR/LF signal or just one of these). Don't like the idea that it doesn't print its own test page though....
Dec 01, 2009 | Ricoh Aficio CL7000 Laser Printer
After installing new ink cartrages the two red lights keep flashing and I can't check the cartrages to see if they are seated properly
Do you have a message on your screen ??? Try printing a document or opening the print manager and see the error message - that looks like a maintenance error when your pads need to be serviced after a set number of prints.
Press the button to set the carriage in ink change position - while your carriage is in the ink change position UNPLUG YOUR PRINTER.
ONce printer unplugged from electrical wall socket - remove all carts, and then place them back one by one making sure you use the right color for the right slot - make sure they snap in securely, close the latch.
Now plug in your printer and wait for the initialization process and see if this works....
If you still get the blinking lights, you will need to locate the error message - your printer pad counter has reached its maximum and it needs to be serviced and reset.
There are reset software out there, but you need to change the pads or divert the tube to a tank outside your printer.
Sep 26, 2009 | Epson Stylus C86 InkJet Printer
Parts inside printer are at the end of their serivce life
In the printer software there is a counter that after printing a certain amount of pages (depending of the printer model) will display the error message and block all printing. The solution is to reset the counter to 0.
Download the http://www.ssclg.com/download/sscserve.exe (its free) once download completed click on the sscservve.exe to launch the setup of SCC service utility. When you close the program, a printer icon should appear on you taskbar.
Using the application:
Right click on the printer icon:
Among the different options provided select the Protection counter option.
Select the Show current value option. You should obtain information about the current value (number of pages already printed) and maximum value.
If the current value is greater than the maximum value, this indicates that the problem is due to the number of pages already printed.
Reselect the Protection counter option, click on the Reset protection counter and then on Clear Counteroverflow option.
The current value should be reset to 0
Restart your PC , your problem should be solved.
Jul 16, 2009 | Epson Printer
Printer error
Jacob
www.kobis.com
Nov 10, 2008 | Sony SnapLab UP-CR10L Digital Photo...
35 people viewed this question
Top Sony Office Equipment & Supplies Experts
matt martin
matt martin
Paul Bade
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
