Either compressor not working or out of refrigerant.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
SOURCE: Coleman Evron CH/CA unit won't blow the air through the vents
Relay for fan operation in the cooling mode may be bad and not bringing on the blower for the air.
SOURCE: nissan 2000 ac hot when idle
the a/c condenser has a fan in front ( there is actually 2 fans if you sit on the car it will be fan on right side ) if this fan does not
come on immediately when you are parked and engine in idle
there is a problem with power to it, or motor failure. If you drive it
on the highway and a/c operates fine that's because air is circulating though condenser (thats what the fan is supposed to do at idle or slow traffic)
SOURCE: carrier air-v AC is not blowing cold air
There could be a freon leak, or just low freon levels. If this is the case, you have to call a certified a/c technician to recharge your system.
SOURCE: window ac unit is not blowing cold air
When the unit is running, go outside and put your hand near the condenser fins, this air that comes out should be slightly warmer than the ambient temp. If it is not you will need to take the unit out of the window and out of its outer case and clean the condenser fins from the inside, this is no easy task as it is very hard to reach. You will want to get a small (toothbrushed sized) brass bristled brush with a long handle. Make sure the evaporator coil (in the front) recieves the same attention and wash the mesh filter that goes in front of the evaporator. Re- assemble and enjoy the cold air.
SOURCE: My AC unit wont blow the cold air.
No, you probably have a bad evaporative fan motor, capacitor or switching. It usually takes a Pro 1/2 hour to track down such a problem with good training.
