Jets, heater and no circulation when I get E1 error code. Bubbles only thing working and this is a replacement unit!
Hi John
Have you had this resolved as I have the same issue.
Ive came to the conclusion its a new filtration/circulation pump.
When I press bubbles on its own it stays on, when i press filtration on with bubbles it stops and flashes E1 and when heating is pressed it also says E1 as filtration comes on with heat.
Im reluctant to buy pump and then its something else.
thanks
Dougie
SOURCE: mspa hot tub, fault code
Try cleaning debris from water outlet screen(upper ouput port) unscrew screened grey cap, code is for rise in water pressure in unit, or its a faulty pressure switch, i figured this out on my own , company offered no support whatsoever, even on warranty
SOURCE: fault code on hot tub
Need more information on the tub. Do the circulation and therapeutic jets work?
