The large hob on my 7 hob cooker,happened after the wife gave the cooker a good clean
SOURCE: oven does not work
its just your heater element you will need to wright down your model number and go on ebay or go to your local appliance shop they might order you 1 there about £35 pound
SOURCE: gas cooker keeps igniting
Sometimes when I clean my cooker, and it gets damp, mine ignites like that. It soon stops after it dries out. Give it chance and see.
SOURCE: Gas oven ignites only intermittent
I assume you are saying the oven will not light but you can see the igniter glowing....if this is the case you will still need to replace the igniter, igniters need to be drawing a certain amperage before the will open the gas safety valve. in this case your igniter is glowing unevenly orange and is old - it is not pulling enough amps to open the valve. Replace it and you should be good to go If you have any other questions please feel free to comment. Good Luck!!! Mike
Testimonial: "Yep, spot on! Ignitor replaced today. Reliably informed that the glow ignitors last about 4 years (ours did 5). That brand now has spark ignition."
SOURCE: Looking for a wiring diagram for a Smeg Cooker
hi could you please email me the wiring diagram for a smeg snz91mfx to [email protected] or call me on 0278264558
chea luke frm the conection company
SOURCE: nothing happens with the ignition, no spark at
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
