Question about Golf
I HAVE A BAT-CADDY MODEL X4 GOLF CART. I CANNOT CONTROL THE SPEED. WHEN I ATTEMPT TO TURN THE KNOB THAT CONTROLS THE SPEED IT JUST RUNS FAST.
Posted by IRENE GALIOTO on
5 Related Answers
Anonymous
SOURCE: Kitchenaid K5A mixer 10 speed only runs on fast, no slow speed
Pull the back off and there will be two screws at the top of the Speed Control Plate and a 3rd screw at the bottom. Tighten the top two screws down. [email protected]. Let me know if it works.
Posted on Mar 21, 2009
comax
Corey McConnell
  • 154 Answers
SOURCE: Ryobi Scroll Saw runs at maximum speed
Unfortunatly the speed controls cannot be repaired, they can only be replaced. You will have to find a Ryobi dealer in your area and get a new speed controler.
Posted on Apr 15, 2009
luxur4
Ron Jones
  • 92 Answers
SOURCE: hobart 135 wire feed sped control problem
you have a resistor down, first check the resistor on the centre pole then those going off to the two other pins
Posted on Oct 09, 2009
Brandon Undeberg
  • 174 Answers
SOURCE: golf cart smoking
It is most likely related to the rings, but running it would unstick them very fast if they were stuck. It's possible that sitting let rust develop in the cylinder walls and there may be some grooves in them now. They could also just be really worn cylinders. They make some oil conditioners which I wouldn't recommend on a car, but might work fine on a golf cart. I can't recall the name, but it was in a silver can, maybe called engine restore... You could always try that before resorting to a rebuild.
Posted on Nov 12, 2009
Testimonial: "thanks for your advice. I will try an additive before a rebuild."
golfcartman
  • 34 Answers
SOURCE: club car golf cart intermittent no spark
What you have is a bad ignitor. It is a small part located behind the RPM limiter. Getting to it is a little tricky but I will try to explain. On the front of the motor, you will find 2 10mm bolts holding a black object that is the RPM limiter. Take these two bolts out and you will find the silver part behind the black box. It will have one wire running to it. The reason it is intermittent, is that heat from the engine builds up and the heat causes it to be bad. When it cools down, it will go to running again. The part runs about $50-$70 . Replace and make sure the connection fits snugly and that the wire that was under one of the bolts goes back on.
Posted on Apr 22, 2010
What is the right air pressure for sun mountain golf cart
8.What is the recommended tire pressure for the Speed Cart pneumatic tires?
The recommended tire pressure is 30 psi.
FAQ ' Customer Care - Sun Mountain
https://shop.sunmountain.com/faq.html
You may also purchase products directly from any of the preferred internet retailers or shop.sunmountain.com. ... If the tire pressure checks out and you have a cart outfitted with bungee cords or strapless bag bag bracket you can adjust the alignment by following the instructions in your user's guide. If you have an older cart ...
[PDF]Speed Cart® SVl User's Guide - Sun Mountain
https://www.sunmountain.com/images/userguides/SV1_UserGuide.pdf are perfect for balls, tees, snacks and keys. • Mesh headcover tray. accessories include the. Speed Paq and. Umbrella. • Ergonomically designed to push without straining your shoulders or back. • Large diameter f tires are maintenance free. I. • The E-Z Latch System / makes folding and unfolding the cart simple.
[PDF]Speed Cart® V2 User's Guide - Sun Mountain
https://www.sunmountain.com/images/userguides/V2SpeedCartUserGuide.pdf Speed Cart® V2. User's Guide. To take full advantage of the ergonomic features of your new Sun Mountain. Speed Cart, please read the following information. ... on the side of the brackets, place your golf bag on the cart and retighten the thumb ... your manual brake is not holding, first check the tire pressure on the front.
[PDF]Speed Cart Vl User's Guide - Sun Mountain
https://www.sunmountain.com/images/userguides/V1SpeedCartUserGuide.pdf *Reverse these steps to fold and store your Speed Cart. STEP FOUR: STEERING. To steer your Speed Cart push down on the handle so the front wheel lifts slightly off the ground. Then pivot tight or left to change direction, lower the front wheel and go. When adjusting the handle or folding the cart, please note that the tires.
sun mountain golf cart tire pressure Google Search
Mar 12, 2018 | Golf
Six 8 volt batteries in a golf cart show being ba the golf cart runs as same good bateeries
You load tested each battery? Can't be bad if cart runs good.
Oct 03, 2017 | Golf
Electric golf cart won't run on cold mornings. I hear solenoid click but nothing happens. When the temp warms up, it runs normal. I replaced controller, solenoid, speed control and ITS & switch.
Depends on how cold it's getting outside. Cold weather is ******* a battery. Try load testing your batteries. That "clicking" noise makes me believe that it's trying to start, but it's not pulling enough amps. Considering everything that you've already replaced, I would start there. Assuming you've already made certain all of your connections are good. Also, make sure the ground wire for your electrical system is good. Not loose, corroded, etc...
You can even call the local golf course and ask to speak to the golf cart mechanic. I would get several calls a week from drivers when I worked as a diesel mechanic.
Oct 20, 2016 | Golf
I CONNECTED MY GOLF CART TO THE CHARGER AND CHARGER IT FOR A COUPLE HOURS NOW IT WONT MOVE FORWARD OR IN REVERSE.
Troubleshooting a golf cart - APLawrence.com
aplawrence.com > Miscellaneous
Mar 29, 2015 - If you need help with a golf cart, I suggest asking at Buggies Unlimited. .... Within a half hour I had everything in place, cinched down, connected and ready. ...it is still getting power to the forward and reverse other words itsworking and ... I let mybatteries completely drain and now the charger won't turn on, ...
Put Spring In Your Electric Golf Cart ' Golf Cart Talk Blog
https://www.golfcarcatalog.com/golf-cart.../put-spring-in-your-electric-g...
Mar 9, 2004 - On a car with 8-volt batteries, connect a 12-volt charger to each individual ... If you do not have a 'Regen' system, then just put the Forward/Reverse(F/R) switch into the .... speed controller stays dormant and will not permit the car tomove. ..... My other question would be did anything "fail" in the cart prior to ...
About Golf Cart Battery Chargers ' Golf Cart Talk Blog
www.golfcarcatalog.com/golf-cart-blog/about-golf-cart-battery-chargers/
Apr 1, 2012 - Tutorial on golf cart battery chargers, the basics, what goes wrong, ...BATTERIES ARE DEAD AND CHARGER WON'T COME ON ... This is usually indicated by a car that creeps when the brake is off and the car is in forward orreverse. ... a connected pair of batteries with a 12 volt, auto style battery charger.
Basic EZGO Golf Cart Problems And How To Fix
Feb 09, 2016 | Golf
Adjust break
Follow the brake cable from down the cart until you find the tension bolt. To tighten turn to the left. If you are not comfortable working on the cart, most bicycle shops can repair them for a small fee.
Sep 04, 2013 | Sun Mountain Sports Golf Speed Cart V1
Golf cart smoking
Nov 12, 2009 | Sport & Outdoor - Others
Golf Logo
240 people viewed this question
Top Golf Experts
FastHarley
FastHarley
ray gallant
Kardoc
Are you a Golf Expert? Answer questions, earn points and help others
