Question about Oregon Scientific Measuring Tools & Sensors
My battery problem is with the Oregon scientific barometer projection unit. time in and out and temperature
Posted by Margie Woods on
5 Related Answers
Anonymous
SOURCE: Battery Replacement
I have the same problem with changing the battery.What ever ya do dont try to take it apart! i just did it and found the sides were glued in.Ended up bustin a chunk out of it.
Posted on Feb 06, 2008
Anonymous
SOURCE: Oregon Scientific VR399 Handheld Digital
I have misplaced my driver also and my device is full of recordings I dont want to delete.
Posted on Apr 13, 2009
MNfisherman
Nate Stansfield
  • 11896 Answers
SOURCE: Does any body have a manual for the Oregon Scientific tp326pmr
www.retrevo.com/samples/Oregon-Scientific-manuals.html
copy and paste in your address bar
or
www.oregonscientificstore.com/oregon_scientific/.../faq.asp
Posted on Aug 27, 2009
Anonymous
SOURCE: Manual for oregon scientific rm313PNA
http://pdf.smithgear.com/RM313PNA.pdf
Posted on Dec 20, 2009
Anonymous
SOURCE: oregon scientific IWA 80055 Outside temp won't
I have the same unit (IWA-80055) and after not finding anything helpful on the net, I just messed with it until I got it fixed. Here's what to do:
1. Take the cover off the back of the remote sensor.
2. Set the chanel to ch.1. (I tried all three but only ch.1 worked for me).
3. Use several tools. (i.e. a stick, needle, what ever you can but you need two) and hold down the reset button on both the sensor and the clock. (at the same time.)
If done right, it should only take a few seconds to start.
The outside temp is delayed at first. Be patient.
Posted on Mar 18, 2010
Oregon Scientific outside temperature sensor not working.
change the batteries and leave it near the main unit for a while to get a signal back
Dec 01, 2017 | Oregon Scientific Measuring Tools &...
Change 12 / 24 hour format on Oregon Bar386
You have to switch C/F to F and then insert batteries :)
Apr 09, 2014 | Oregon Scientific BAR386 Wireless Weather...
The putdoor temperature will not come in
Check batteries in outdoor unit and try moving to closer to the base station.
Apr 08, 2014 | Oregon Scientific Wireless IndoorOutdoor...
I cannot get the outside temperature to show on the inside monitor
Try the usual fix by removing batteries and reinstalling/replacing batteries starting with the outside unit. Wait for as long as 10 minutes for the ouside temperature to be displayed on the indoor unit. If nothing happens after 10 minutes, the outside unit may have failed.
Oct 20, 2013 | Oregon Scientific Bar806hga Helios Solar...
Oregon scientific model no rar186 how to set up outdoors sensor
I have had this Oregon Scientific model RAR186 unit for years and it works great. The only issue I ever have is when the batteries need to be changed in the remote sensor unit (Oregon scientific model #THN122). It never fails that once I change the batteries that the unit does not send a signal to the base unit. I will often hit the reset button and change the channels on the remote sensor before I finally remember that you need to do the following to get the sensor to talk to the RAR186 base unit:
On the base unit (RAR186), hold down the CHANNEL and MEM buttons for at least two seconds.
You will then see a graphic appear above the channel number that shows that it is searching for the sensor.
Within a minute, you will then see the temperature displayed for the sensor showing that they are communicating.
This is buried in the manual that you probably discarded as did I.
Apparently, if your sensor is broken, you can either search to find a new sensor of the same model or also use the following sensors: THC138, THGR122NX, or THN132N
I have not needed to replace the sensor as once I found the instructions to reset the communication between the sensor and base unit, all was fine. Hope this helps someone. I wrote this instruction using a Sharpie on the inside cover of the sensor since you have to remove 3 screws to replace the AAA batteries (2) in hopes I will remember next time and not waste my time searching the internet and not find the answer. Good luck!
Apr 02, 2013 | Oregon Scientific Measuring Tools &...
Remote sensor (thn122) not working, batteries changed, terminals cleaned
Mar 05, 2013 | Oregon Scientific Measuring Tools &...
ONLY SHOWS INDOOR TEMPERATURE DOES NOT SHOW OUTDOOR TEMPERATURE
I have a similar device and the instructions say to remove batteries from both units and wait for 10 minutes without pressing any buttons before installing batteries first in the remote unit then the indoor unit. The outdoor and indoor units have to "talk" to each other before getting in the mood to display temperatures.
Feb 03, 2013 | Oregon Scientific Wireless IndoorOutdoor...
Dashes in my outdoor weather reading of Oregon Scientific station
The signals are not being received by the main unit. Try to reposition the unit or move it to a different location. Also make sure the antenna is in the clear and not next to any thing like a cordess phone or charger as these can make RF noise that can block or cover the needed signals.
Feb 07, 2010 | Oregon Scientific Audio Players &...
Measuring Tools & Sensors Logo
207 people viewed this question
Top Oregon Scientific Measuring Tools & Sensors Experts
Marvin
Marvin
Lawrence Oravetz
Are you an Oregon Scientific Measuring Tool and Sensor Expert? Answer questions, earn points and help others
