Question about Hyundai Televison & Video
I have a Hyundai wall mounted fire but I have lost the brackets for attaching it to the wall during my recent house move
Posted by Keith Royston on
5 Related Answers
Anonymous
SOURCE: Wall mount dyna glo model RMC-40NGT
I have the same one i am looking for the wall brackets, I lost mine. I also bought mine at a garage sale the people had it attached to the wall completely hooked up .they had no fire backer on it .They only took it off the wall when i purchased it
Posted on Nov 10, 2008
Anonymous
SOURCE: Mounting the bracket to the tv?
Hey, I had the same problem and finally found this solution (the four mounting holes are covered by plastic caps as I thought ... just wanted to be sure). Hop this helps:
http://www.avsforum.com/avs-vb/showthread.php?t=1040337
Posted on Dec 27, 2008
Anonymous
SOURCE: I have a wall bracket on the laundry but hjow do I get the dryer on to the bracket
Is the wall dryer bracket, the correct one to fit your hover
Posted on May 28, 2009
Anonymous
SOURCE: Trouble mounting cantilever wall mount bracket to Sony TV
Finally figured out the correct arrangement or configuration through trial and error (and my wife's puzzle solving ability). It sure wasn't clear in the instructions, and I could not get the needed information from the website of either the manufacturer of wall mount system or TV...a little frustrating, but perseverance paid off. Given the price of the wall mount, I would think they could do a better job.
Posted on Oct 25, 2009
Sparky2012
Sergio Shamshoian
  • 102 Answers
SOURCE: hi . i recently purchased a ESA 42in Plasma Model:
I would check on ebay until find one, no one on sale right now
Posted on Dec 06, 2009
Where is the starter on a 1999 s-10
passenger side, under exhasut pipe, against motor, close to tranni.
Jul 17, 2010 | 1999 Chevrolet S-10 Pickup
LG 42" wall mount screw size
Metric M5 or M6, when you buy wall mounting bracket, it will came with a bag of screws for attaching the TV to the bracket. All my wall mounting brackets for my TV come with screw.
http://s807.photobucket.com/home/budm/allalbums
Jul 01, 2010 | Insignia LCDTV26 26 in. Television
Toshiba Regza lost swivel stand bolts
if your GF wants you to separate the three in one coffe what well you do?
Jan 11, 2010 | Televison & Video
Cover does not attach to the universal bracket I purchased
Buy a drill and drill bit and make a hole in the bracket where needed. To make installation easier, use a larger that needed drill bit and add washer to screw, won't look as professional but you are not a professional anyway. Who goes around looking at ceiling fan mounts anyway???
Jan 13, 2009 | Hampton Bay 73554 Antigua Ceiling Fan
Nov 02, 2008 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Heater Core
1) disconnectnegative battery cable
2) remove coolant reservoir
3) dis-connect heater hoses from heater core and plug holes in heater core, some coolant will drain out
4) remove mounting bolts and nuts on fire wall
5) remove glove box liner and door
6) lable and dis-connectheater controls
7) dis-connectand remove computer and mounting bracket
8) move radio antenna wire
9) remove kick pannel and un-bolt lower corner of dash
10) remove screws and nuts holding the housing inside the cab
11)remove the heater housing from the vehicle
12) detatch the core retaining straps and remove the heater core
13) installation is this procedure in reverse
I hope that this fixes your problem good luck and please take the time to rate this response.
Oct 17, 2008 | Chevrolet Suburban 1500 Cars & Trucks
Attaching 26 " lcd to stud wall
12 inches is the minimum for mounting the unit to the wall. I mounted a 42 inch LCD using a Sanus tilt (non-swivel) mount from Best Buy. We mounted it on wooden beams exactly 12 inches apart. Works great!
Mar 05, 2008 | Televison & Video
How do i attach a Wall Mount to the TV?
Hi, Ok, great.Look at the back panel and you can see four holes spaced 4" between the top and bottom, and 16" from side to side. these are for universal mount. http://www.bestbuyplasma.com/Plasma/tvmounts_land.asp I think this clears your problem regards sreejith "Please use caution if wall mounting this product. Follow all directions from the manufacturer of the wall mount and be sure to securely fasten the product to the mount. While the TV can be wall mounted, improper wall installation may void the warranty."
Jul 16, 2007 | Akai LCT3285TA 32 in. LCD Television
Televison & Video Logo
22 people viewed this question
Top Hyundai Televison & Video Experts
Marvin
Marvin
MODERATOR WORLD
Are you a Hyundai Televison and Video Expert? Answer questions, earn points and help others
