Question about Food Processors
Hi there, i was hoping someone could help me. I lifted the blade on my kitchen aid food processor and it's now locked. the processor works but i'm unable to push the blade down.thank you!
Posted by Rose Popovski on
5 Related Answers
abo gato
SOURCE: food processor, kitchen aid piece
Mine is stuck too.....I have not been particularly happy with this Kitchenaid product and this may be enough to send me back to Cuisinart.
Posted on Jun 08, 2008
Anonymous
  • 24 Answers
SOURCE: GE Food processor knife blade, bowl and cover .
plz con-022-23095757 / 23051554
Posted on Feb 03, 2009
QuietRiot
  • 145 Answers
SOURCE: I have a kitchen aid food processor, it is on, but motor doess no
This sounds like an issue relating with the assembly of the machine. The motor is definitely getting power if the indicator is lit. However, Kitchenaid food processors are designed (as a safety feature) to remain unengaged if the unit is not assembled in such a way. Here is the proper assembly:
Please disassemble the unit. This means: removing the blade, removing the work bowl, the work bowl cover, and unplugging the unit.
Starting with the work bowl: place the handle at the 9 o'clock position, which is out to the left. Rotate downward to the 6 o'clock position until it locks in, centered over the button panel.
Repeat the process with the work bowl lid.
Depending on which food processor you have, you may need the feed tube pusher depressed at least half way down the feed tube.
Plug in the unit. The blade does not have be installed for unit it to work at this point, assuming everything is assembled properly and the motor is functioning. The motor should now be working.
Posted on Jul 07, 2009
Anonymous
  • 72 Answers
SOURCE: My 12 cup kitchen aid food processor dough blade
Dough is normally water soluble. Try soaking it in water for a several days up to a week. Then try prying it loose.
Posted on Sep 17, 2009
Dave
  • 5 Answers
SOURCE: I just bought a 7 cup kitchen Aid food processor and I can't get it to work. I have gone throught the assembly instructions several times like the book shows but still won't turn on. Model #
Make sure the bowl is locked in properly. That is the normal problem.
Posted on May 21, 2012
The bowl of my 14 c food processor will not release from the base - the cutting blade is in place
You will probably need to force the blade off the shaft somehow. If you over work them the blade can partly turn and lock onto the plastic shaft sleeve. A Kitchen Aid Authorised repairer will have figured out a way to remove it by now because it's been happening for years. Expect to replace the blade or the sleeve or both, once it's happened it's easier to happen a second time unless you replace parts.
Nov 23, 2017 | Food Processors
How do I get a dough blade for kitchenAid food processor Model 4KFP 600 WH
Kitchen Aid list them, it's on this page called blade, dough
http://www.kitchenaidpartsonline.com/modellookup/index/thirdstep/keyword/KFP600/model_no/KFP600WH/model_id/398686/diagram_id/10083552
Feb 24, 2015 | KitchenAid Food Processors
How can I get kitchen aid blade out that is stuck
The blade will be stuck on the shaft and both will be damaged and require replacement. With that knowledge you now understand that drilling a hole sideways through the blade cap isn't wrecking anything you are going to use again. You can then get something into the hole for leverage. Here in NZ blades are under $20 and motor shaft sleeve is about $5. If you don't replace the parts it will happen again.
Aug 11, 2014 | KitchenAid Kitchen Aid 13-cup Food...
Kitchen aid food processors 's chopping blade gets stuck . Very hard to take it out
The shaft sleeve (the one on the motor shaft) is likely damaged. The correct solution is a new shaft sleeve and chopping blade. If you do not replace them both together the one you do not replace will damage the other one again.
Aug 23, 2013 | Magimix 5100 Cuisine Systeme Food...
MY KITCHEN AID FOOD PROCESSOR ONLY WORKS IF THE LOCK IS OPEN WHAT SHOULD I DO
Just because they cannot help you for free does not mean that there is no help at all. Ask them who is your local K/A service agent and see what he has to say.
Nov 23, 2012 | KitchenAid KFPW760 12 Cups Food Processor
May 09, 2009 | KitchenAid Food Processors
Kitchen Aid food processor, model # KFP 700 from 1970s
The closest I have seen recently - there is an auction for a complete KFP-700 with work bowl/lid intact on eBay right now:
http://cgi.ebay.com/Kitchen-Aid-12-Cup-Food-Processor-model-KFP-700_W0QQitemZ150328616612QQcmdZViewItemQQptZSmall_Kitchen_Appliances_US
-Tha Mp3 Doctor
Mar 12, 2009 | KitchenAid Food Processors
Can't get it to start
I have a Bravetti EP 199, and I have the same problem. I can not get it to start. It is dead. Cold dead. Do I understand you posted your problem since Nov. 18, and you are waiting to get help?
Nov 18, 2007 | Bravetti Quad Blade Food Processor
Food Processors Logo
227 people viewed this question
Top Food Processors Experts
Marvin
Marvin
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Food Processor Expert? Answer questions, earn points and help others
