Televison & Video Logo
Where can i find a replacement screen for a Vizio D65U-D2
Posted by phillip on
4 Related Answers
emissionwiz
Marvin
  • 85241 Answers
SOURCE: What size screw do i use for a D65u-D2 vizio tv. I cant find the screws to the tv stand
You would need to measure the screw hole and buy the at a hardware store.
Posted on Dec 30, 2016
Larry
  • 4631 Answers
SOURCE:
Change the power board or look for bad capacitors, this is a common issue when filters are going bad..Good luck
Posted on Nov 30, 2017
Larry
  • 4631 Answers
SOURCE: vizio 65in Model D65u-D2 I have a black screen with sound.think it may be led driver but i can change format to small and take off HD channel and it will stay on. would this still be the led driver?
Most likely not...sounds like a software issue to me
Posted on Dec 13, 2017
twoarcadians
Gary F
  • 245 Answers
SOURCE:
Most common problem with LED TVs is the power board fails.
Posted on Mar 17, 2018
2helpful
Vizio D65u-d2 Backlight not working after replacing 2 LED strips?
You should be able to replace just the bad LED strips however with as much work as it is to get the set apart and back together I always replace all them as other strips generally fail in time. Did they all light up after you replaced the bad ones before you put it back together? This model set has local dimming so servicing it is a bit more complex, you could have a bad backlight driver but that board seldom gives issues, also you could have main or power board issues as power for the backlight driver comes from the power board or you could have main issues as it's the signal from there that turns on each strip.
2answers
Model d65u-d2. Why does it have a black screen?
only an educated guess back light is the problem , might be power supply of the led strips call a local repair shop
Hi, I have Vizio d65u d2 Screen goes black after 3 minutes, I change power board supply and led board, but still same problem
Hello
Make sure the connectors are snugly in place and that the set in not i a position that stress the boards, reset all settings then
change the picture mode to standard and auto brightness to medium
Good Luck
Mr.Mike
Vizio model d65u-d2 NO POWER How to troubleshoot power on problems
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Top Televison & Video Experts
Marvin
Marvin
