SOURCE: CD CHANGER EJECT BUTTON
Inspect the tray or door to see if there is a very small hole in it. If so, this is an 'emergency' ejection hole and a standard paper clip, unfolded, can be inserted there to manually eject the tray. This is a real common problem caused by the slippage of a clutch mechanism that is supposed to protect the tray mechanics from being damaged if the tray is somehow impeded during its travel. It must be tougher than rocket science to properly design this feature -
SOURCE: 2007 nissan maxima will not load or eject CD's...or even play the
Hi, this is a common issue within car CD changers. the load motor go through lots of trauma during the life span that i usually 3 to 5 years. the load motor operates everything in the changer. it works the load tray and spinning of the disc as well. when this motor is out, the changer will be rendered useless. replacing the load motor will fix this issue or, you can just purchase a new changer and save a lot of money.
SOURCE: Dell Studio 17 Stuck Disc in drive
if you look close infront of the cd-dvd playerdoor there is a little hole if you stick a paper clip in there it will eject it.
SOURCE: cd changer won't play, load, or eject
Had the same problem on our 03 yukon (not the changer but the main head unit) - have a 3rd party waranty and they replaced it. You can get the part for less than 300$ and it's easy to install.
SOURCE: Hyundai CD player displays ''error'' for all functions
my cd player in my sonata keep eject the cd can anybody help
SOS
