Question about Brother Office Equipment & Supplies
Brother printer j470DW SHOWS DL ROM on ther screen what shall i do
Posted by majid on
Marvin
    Top Expert:
  • Brother Master
  • 85,239 Answers
Posted on Jun 13, 2018
Testimonial: "that was not made for the model that i have , it doesn't work , can we got something pls ."
  • Marvin
    Marvin Jun 13, 2018
    Sorry that is all the info I have
2 Related Answers
SOURCE: my brother hl-6050dn printer shows
The machine has a fuser error and will need to be replaced
Posted on Feb 14, 2011
k24674
  • 8091 Answers
SOURCE: My Brother MFC-J470DW Printer scanner will not scan to my email account
Something might have changed. Just check what is your default E-mail application and do reconfigure it or run a repair command (for Outlook for example). Reboot to make sure that the changes are applied.and, if need be, reinstall the Control Center again.
Open the scan to E-mail configuration and select the application that handles the E-mails.
If that does not work there is a workaround: Scan to pdf then send the pdf file as attachment. From your E-mail account you may also be able to insert a file acquired from the scanner.
Posted on Dec 28, 2013
How do I clear the memory for my Brother MFC-J470DW all in one printer? I'm using a Mac if that makes a difference.
Go here:
http://support.brother.com/g/b/faqendbranchprintable.aspx?c=in&lang=en&prod=mfc8220_as&faqid=faq00000195_002&printable=true
Feb 09, 2018 | Brother Office Equipment & Supplies
Brothers printer without a computer
If this is a Brother MFC-J470DW Inkjet, then it is possible to connect it to a wireless network. If you internet device is actually a "wireless router" as well as a modem (where cable or phone line connects) then you should be able to follow the manual in setting up the newtork on the printer. You may need a phone, iPad or other device that can browse the internet, to register the printer properly and complete setup. There should be a support number you can call for free (check your setup documents). Most companys are anxious to help new cutomers and give them step by step instructions. You can also try http://www.brother.ca/en/customer_care - there are several support option there.
NOTE:
If your internet modem is not a router and only has a wired connection for direct to a PC (a cable that has what looks like big phone jack ends), you would have to add a wireless router instead of a PC. This can be a complicated job, and beyond the scope of this answer.
This printer does support Google print, Apple AirPrint and other network printing (for phones, ipads etc) so once connected, it could be very useful. Brother Canada Customer Support
Jun 03, 2016 | Brother MFC-J470DW Inkjet All-In-One...
Setup mfc-j470dw wireless printer
you should have got a setup disk to run in your computer to set it up look for that disc
Feb 26, 2015 | Brother MFC-J470DW Inkjet All-In-One...
How do i get to print my web stuff coz my brother MF-J470DW is sending blank papers without prints
If you machine prints other things without problem, then you should be more specific about what web stuff you are trying to print. Often web based images are in frames or links, and these can be very difficult to access or print. You may need to download or screen-dump the content before trying to print it.
Dec 02, 2014 | Brother MFC-J470DW Inkjet All-In-One...
How to change to double sided printing on mfc-j470dw
Double sided printing it usually set in the software.
For example: printing from Chrome, go to the print screen and at the bottom of the list are options, choose two-sided.
- MS Office, choose print, then choose Properties (next to the printer listed), it is on the first tab - Layout.
Aug 19, 2014 | Brother MFC-J475DW All-in-One Inkjet...
"please dl rom" scritta su display LCD
If you have tried to change language, the problem is the Upgrading and the country code
Apr 01, 2014 | Brother MFC-J6510DW Multifunction Inkjet...
Brother MFC j430W. How do I correct machine error 48?
The print head circuit or cable is malfunctioning or faulty. Replace the printer. I would suggest the Brother MFC-j450dw/j470dw printer as it is an upgraded and newer version of the j430w. Good luck!
Mar 16, 2013 | Brother DCP 165C Compact Color Inkjet...
418 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Norman  J Weimar Jr
Norman J Weimar Jr
