SOURCE: Coleman generator OHV3000
The carburetor is probably clogged up. Mix a bottle of carburetor cleaner with the gas to see if that would help. Also check/replace the fuel filter.
SOURCE: motor runs wide open but no power from generator
You will need to install new diodes,they are located in the plastic housing behind the receptacles...It looks like little spark plugs..They work to put dc voltage to the rotor,without the exciter voltage applied,you will not get ac power out..The part number is 3483.01....You can buy these online for about $6 each,they have 2 inside the generator,and you should change both.
SOURCE: throttle control won't work after i cleaned the
Hi again Ed,
Starting at the carb throttle shaft, your linkage rod (with tiny spring wrapped around it) should be connected directly to the governor's arm. If there's more than one hole in the arm, connect the rod in the upper-most hole.
Now, at the base of the governor's arm is another hole (possibly on a tab jutting from the arm). The main governor spring should be hooked in this hole and then back to the sliding throttle control that moves when the lever on the dash is moved. (This one definitely has a tab and hole.)
The choke cable end hooks directly on the choke shaft and it has intuitive movement. Verify that the choke butterfly closes and opens relative to the cable control on the tractor's dash.
To insure that we only do this procedure ONCE, and we get it right the first time, let's set the internal governor to base-line at this time.
With everything bolted back up, move the throttle control lever on the tractor's dash to full throttle. Then get a 3/8 wrench and a slotted screwdriver and locate the round governor shaft coming out of the engine block. The governor arm attaches to this with a clamping-bolt. You will notice that the round shaft is slotted for a screwdriver as well.
Loosen the clamping bolt slightly with your 3/8 wrench, insert your screwdriver and rotate the round shaft clockwise until it stops. (It has VERY little travel, so turn it both ways to verify that your are at FULL clockwise position.)
Hold screwdriver there and move the governor's arm in the same (clockwise) direction until the carb's throttle is set to WIDE OPEN throttle. Still holding the screwdriver clockwise, retighten the clamping bolt with the wrench.
Next, move the throttle lever on the dash of the tractor to idle and back to full several times and observe the carb's throttle shaft, it should come down from full throttle to idle and back again freely.
Start the engine and be prepared to shut it off if it over-revs.
If it doesn't over-rev, your base-line settings are correct.
By bending the tab on the sliding throttle control (the one that has the main spring attached) you can now increase or decrease spring tension and change top speed of the engine. Do this in small increments and if you have a tachometer for single cylinder's set top speed to 3400-3600 RPM.
Sorry this is lengthy, but as mentioned above, we only want to do this once.
Hope this helps, and feel free to ask away if you need more info!
Dolf-
Testimonial: "thanks for the advice , i got the mower running well now. ed"
SOURCE: We have an IH 460 Farmall. It ahs been running
check the carb out clean it and the lines also just to be sure check the sparkplugs
