Question about Blaupunkt Televison & Video
I have a Blaupunkt portable DVD player and just now the 'low batter' icon flashes even when it is fully charged.
Posted by Damien Wilmot on
antoniorojas
    Dedicated:
    Visited the website for 20 consecutive days.
  • 280 Answers
This is why its doing that your battery almost done they usually dry enough and its not able to hold the complete charging cycle
solution buy a new battery
Posted on Apr 27, 2019
5 Related Answers
Anonymous
SOURCE: DUR-7 portable dvd player battery life?
Wal-mart does sell replacement batteries. http://www.walmart.com/catalog/product.do?product_id=2350787 For this particular unit. However; in the future I would suggest researching a particular item before buying esp from Wal-mart. As Durabrand doesn't even have a website.
Posted on Dec 04, 2007
Anonymous
  • 121 Answers
SOURCE: after one frame battery icon flashes ( battery is full charged)
The problem is with the electric contacts between the battery and the camera. You can try cleaning them with a clean pencil eraser. Make sure you don't leave any eraser debris in the battery compartment. It is best to do this while holding the camera so that the battery compartment door is "down" so that any eraser debris will fall out of the door onto the table rather than fall into the compartment.
Posted on Dec 12, 2008
SOURCE: charged battery only lasts 30 minutes
Try fully draining the battery and recharging it fully. If that does not work chances are the battery is going bad. How old is the dvd player ? If its still under warranty you might be able to get a replacement.
Posted on Jan 05, 2009
mrfixie
  • 303 Answers
SOURCE: craig portable dvd player
You can buy a new one by clicking on the hyperlink:
buy replacement ac adapter power charger cord for Criag portable dvd player
Posted on Mar 05, 2009
A1B2C3D4E5
Keith Gee
  • 4 Answers
SOURCE: portable DVD player will not charge
I own the same DVD player. If the player runs from the AC Adapter but not from the battery (Adapter plugged into the battery) chances are the battery has worn out and it needs to be replaced. Trick is to find a battery for less than $40
Posted on Jun 23, 2009
My portable rca dvd player will only keep a charge when plugged in
-Battery is too old. All charge able battery last only 2-3 year or maybe even less than that depend on how you use.
-If just a little low and keep charging then it life is short.
-If let it fully empty (dead) before charge the it last longer.
Good luck
Mai
Oct 04, 2016 | RCA DRC6309 9 in. Portable DVD Player with...
I have a MDP845 Magnavox portable dvd players that looks to be charging but the light flashes orange and green and is not charging. The manual says that it will flash orange when charging and when fully...
Likely the battery but it could also be the charger---if someone tests the voltage coming out of the charger with a volt meter it will eliminate that as the cause
Mar 24, 2012 | Televison & Video
How long does the fully charged batter last when watching a dvd
Good Question,
The manufactures ratings are based on testing purposes that your MFG. Battery willl last approx 2.5 hours on a full charge.
You can purchase longer lasting batteries up to 6 hours but there pretty steep in price.
Thanks for your question, please be considerate when rating to be positive and leave feedback.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jul 01, 2010 | Audiovox PVS3393 9 in. Portable DVD Player
How should i store my poetable dvd player battery?
Store it full charge. If you store it low charge, then battery life will be compromised. Research and tests have proven that storing batteries full charged will extend its life. Also make sure that you charge stored batteries every 3 months to further extend its life.
Nov 08, 2009 | Sony Televison & Video
How do i charge the venturer pvs3361 portable dvd player? do i just plug in the connector from the dvd to the outlet? and let it sit?
Most of these players have a "charge" switch location on the three position power switch (Charge... Standby... On). If not, just set it to off. The unit normally flashes the green light when it is checking the batter condition, solid green when it is charging and the green led goes off when charged.
Best of luck!
Nov 06, 2009 | Venturer PVS3361 Portable DVD Player
Charged battery only lasts 30 minutes
Jan 05, 2009 | GoVideo DP5040 Portable DVD Player
Durabrand PDV709
According to the manual "the LED Indicator will flash when charging the battery and will be steadily on when the battery is fully charged."
If you would like a copy of the manual, I can sell you one for $8.99 including shipping to lower 48 states. If interested, email me at [email protected].
warm regards,
Marisa
Jun 22, 2008 | Durabrand PDV-705 Portable DVD Player
Bulge battery!
I have a battery for your dvd player. You can contact me at [email protected]
May 07, 2008 | Durabrand DUR7 Portable DVD Player
How do I charge battery
Simply hook the battery up to the player, plug in the adapter (house AC outlet, car adapter will not recharge batter), and turn the unit off.
The charging light should come on and when it goes out it's fully charged.
Jan 18, 2008 | Durabrand Portable DVD
Televison & Video Logo
Top Blaupunkt Televison & Video Experts
Marvin
Marvin
Vernon Taylor
Andrew Taylor
Andrew Taylor
Are you a Blaupunkt Televison and Video Expert? Answer questions, earn points and help others
