Question about GE Lands Phones
How can I set the date and time on a GE phone, model# 29582fe-1?
Posted by Elridge Nelson on
5 Related Answers
Anonymous
SOURCE: cant set date/time on model#exi4560vuniden phone
Press "clock" and hold for a few seconds.It will say the day. If the day is wrong, use the arrow keys to move either forward or backword through the week. When the day is set press "clock" again and you will hear the hour. Press the arrow keys to move the hours. Press again for the minutes and use the arrow keys to set the minutes. Last press "clock" again and set AM or PM. By the way, the manual does not tell you how to set the clock.
Posted on Oct 08, 2008
Anonymous
SOURCE: setting date and time
J'ait oubier quement changé la date et heur model est le M7310 mon couriel est le [email protected]
Posted on Oct 22, 2008
Anonymous
  • 91 Answers
SOURCE: set time and date on ge answering machine
This manual will be helpful for you.
http://www.theusermanualsite.com/mdownloads/f3aad742-2c3f-8ec4-f59b-7c77da824583.pdf
Posted on Jan 06, 2009
Anonymous
SOURCE: want info on how to set date & time on GE phone
thanks for concern, problem not solved and do not under stand why one has to go through so many hoops just to get a problem solved thanks, but no thanks
Posted on Apr 10, 2009
Anonymous
  • 25 Answers
SOURCE: Time doesnt get set automatically
sir, there is no solution for this prolem.you will have to set it manually only. if you dont the default settings will be set.
Posted on May 28, 2009
The answering machine on my ge model 27909 is recording the wrong date and time for when the message was left. Can't find anywhere in the manual on how to fix this
try setting the original time on the machine correctly
all recorded data is set from that original time setting
Sep 27, 2018 | GE Lands Phones
Need information on how to set time & date on a GE
Press and hold the STOP/SET button for two seconds, then release to access the set-up menu. The time/date setting follows the language.
The full details are in the "Changing the Settings" section of the manual (page 10 in my copy). If you need a copy of the manual, you can download one at
http://www.home-electronics.net/ge/pc/IB/29875GE1_IB.pdf
Sep 23, 2011 | GE Cordless Phone & Answering Machine...
How do I set the time and date on a GE phone Model # 29490ge-2
"REMINDER: The time and date are programmed automatically when the first Caller ID record is successfully received after set up."
The quote is from the fifth column of the first page of the manual at
http://www.home-electronics.net/ge/pc/IB/29490GE2_IB.pdf
Sep 01, 2011 | GE 29490GE2 Corded Phone
My Model # is 27957FE 1-A Dont know how to reset
To set the time and date, start at the base unit. Then press the Flash/Program until Set Day appears on the display. Press the Review or Next button to select the day of the week. Then press Flash/Program again until SetTime appears in the display. Type in the time (hour (two digits) then minute (again two digits)) with the keypad number buttons. Then press Review or Next to select AM/PM. Press Flash/Program to store the information.
Please note that if you have Caller ID, the time and day transmitted with the caller ID information from your phone company will override the day and time you have set.
The manual is available here: http://www.home-electronics.net/USER-GUIDES/27957_DOM_ES_CL_IB.pdf . See page 15 for this.
I hope this helps.
Jun 01, 2011 | Thomson GE-28115FE1 Cordless Phone
Ge model 27909 answering machine gives wrong time on playback
I found it on the manual, it was in programming section!
Date/Time
NOTE: Time set on handset will be transferred to the base unit automatically.
1. Make sure your phone is OFF (not in talk mode).
2. Press the menu button to go to the main menu and use cid/vol (3or4) button to scroll to Date/Time.
3. Press menu button to enter the menu. Year 2006 shows in the display.
4. Use the touch-tone pad to enter the last two digits of the current year (range: 00 to 99).
5. Press menu button to save the year setting and proceed to date setting.
6. Date 01/01 shows in the display. Use the touch-tone pad to enter two digits for current month and day respectively.
7. Press menu button to save the month/date setting and proceed to time setting.
8. Time 12:01p shows in the display. Use the touch-tone pad to enter four digits for current time and use cid/vol (3or4) button to toggle between "p" (pm) and "a" (am).
9. Press menu button to save the setting. Saved shows in the display.
NOTE: If you subscribe to Caller ID service, the current date/time is set automatically when you receive your first CID record and will override manually set date/time.
Jan 08, 2009 | GE Lands Phones
GE 25942EE-C model date time stamp
I cant program my phone.The CL light flashes and I cant do anything.
May 20, 2008 | GE 25942GE2 Cordless Phone System
GE Dect 6.0 digital cordless phone about 1 year- old how to set time
I have a GE 6.0 cordless & it did work great but, Now for what ever reason it crackels & the static is so bad i can not understand those who call me . I love this phone so please help me. ?
Mar 08, 2008 | Uniden Cordless Phone
Setting date and time
I have a 900MHz extend A phone type Uniden and I would like to know how to set the time and day on the answering system
Feb 06, 2008 | Lands Phones
GE 27831 Cordless - Date Time Issue
should be in the main menu thru the handset setup .unlike cell phones that reset automatically . you must go into setup and do it
Dec 23, 2017 | GE 27831 Cordless Phone
Lands Phones Logo
302 people viewed this question
Top GE Lands Phones Experts
martin hogg
Bruce Robin
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
