Question about Sony Cameras
SOURCE: Memory Stick error c:13:01
Is your new 2GB memory stick is original from Sony or after market? some of them will not detect in CAM because the contact on MS were not touched iside the slot of CAM
Reinsert your 512 MB MS if it work fine then change your 2MB MS
Good luck
Posted on Nov 30, 2008
SOURCE: Sony Cyber-Shot DSC-w5 "MEMORY Stick LOCKED" ??? please help!
take your memory stick out of your camera and theres this sliding thing on the back...slide it so that its not on the lock side? does that make any sense? well..good luck!
Posted on May 14, 2008
SOURCE: sony cyber shot DSC F717
Hi
Switch your camera to Setup on the control **** located on the top.
Take out the memory stick and press the reset button located inside the battery compartment.
Now switch on the camera and insert the memory stick.
If you do not get the error go to the little toolbox on the menu. Select the format option and proceed through the warning messages. Remeber you will loose all data on the memory stick.
Things should now work. If not some simple thing that sound bezare but has worked for me is pushing the memory stick in and out before the camera displays the error. Do this several times until the camera actually reads the stick and them format the stick first chance you get.
Good luck.
Posted on Mar 09, 2008
SOURCE: memory card
Hi - no, the DSC-P7 isn't compatible with Memory Stick Pro, only original Memory Stick, meaning you're limited to 128MB/stick. Having said that, the P7 is only a 3.2MPixel camera, 128MB will hold quite a few pictures, even at full resolution.
Posted on Nov 08, 2007
SOURCE: Sony cyber shot DSC S930 "Reinsert Memory Stick"?
I am having the exact same problem and I have only had my camera for 2 weeks. We took it on vacation and I really want my pictures. Did you find a solution? Was it the memory card or ther camera?
Posted on Jan 01, 2010
