Computers & Internet Logo
A
Anonymous Posted on Jun 12, 2018
I have a slow Internet connection. What do you think about it? Can I improve it somehow?
Nathan Holmes
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 25 Answers
  • Posted on Sep 16, 2018
Nathan Holmes
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
25
Questions
0
Helped
4483
Points
38
You could contact your Internet service provider (or other providers) and see if they have any faster connection speeds available.
2answers
Slow window 7
Yes, I think that could be the cause. You can defragment the drive and that could give the slightest improvement, add RAM might be an improvement, but mostly, your HDD might not have enough room for the required amount of VM (virtual memory).
You didn't mention how big the harddrive; it might be fine. Have you checked for malware and spyware. They can certainly slow down a system.
Running slow
To increase internet speed
* Check to see if faster internet connections are in your area:
Fiber optic and cable internet tend to be faster than DSL and dial-Up.
*Do some basic maintenance on your PC:
a scan disk, a virus scan, a malware scan, and clear your recycle bin.Delete old files and temporary files.
* Reset Your Modem
Sometimes switching OFF and ON your modem helps you to speed the internet.
* Optimize your cache or temporary Internet files.
These files improve your Internet connection performance by not downloading the same file over and over.* Replace your old cable modem
* Upgrade your router firmware
* Upgrade your computer.
* Try pressing Ctrl-Alt-Delete simultaneously and open up the Task Manager. Go to the process menu and close those processes that may be stealing your valuable bandwidth.
* Download programs that make browsing faster:
A good tool to increase internet speed is Internet Cyclone.
Loband.org is a browser inside of a browser that loads web pages without the images.
Firefox and Opera both have options to disable images.
After you have tried some of this,try your connection again using Scanmyspeed.com and see if you get improved speed results. If you are not satisfied Call your Internet service provider (ISP) and check whether upgradation of your plan is necessary.
Unable to login slow internet nimbuzz
If you are facing slow internet connection problem on your mobile phone, Try with the following tips for better internet connection,
* Clear your cookies, browsing history, etc.
* Turn off your background applications.
* Install latest and upgraded browser for your mobile to browse.
* Ensure that you have turned on your 3G settings.
* Make sure that your network gets full coverage
You may get an improved result in connection by performing these. You can check the difference by having a speed test from www.scanmyspeed.com before and after performing these steps. Good Luck Mate,
Apr 09, 2013 • Cell Phones
Computer takes forever to just get connected. I wait and wait and finally it connects. Is this a browser problem, an internet provider problem or what? I just uninstaled Wxp and reinstalled it. Now I...
Doris, when you get Internet Explorer fully loaded, click on Tools, then Internet options, then Advanced, you should see a button that says reset > click this, and wait. close and relaunch internet explorer, see if it improves it. If not, then goto start > Control Panel > Add/Remove Programs Look for any and all entries, that end with Toolbar, and remove ALL toolbars, then once this is done, reboot your computer, and see if there is an improvement. If there is not you need to have a professional clean your computer.
2answers
Need to reboot!My browser is too slow
if you are using internet explorer
all you have to do is go to tool>internet options> the advance tap
and then go to the bottom and click reset
My camera has slow reaction time and constantly feezes. do you think it's my internet connection or just my computer?
Well, it could be bought. Try testing it in an offline environment.. if it improves dramatically it s the Internet, if not it is the computer but that still doesn t guaranty that the internet connection is suitable.
But i would put my money on the internet... that s the most common problem.
1helpful
My Linksys network adapter is very slow to connect
Ask them to review you connection speed to make sure your getting the speed you ordered. Linksys is usually pretty good. See if it's faster WITHOUT using the wireless (plug directly into the modem). If it is I can only think of two things... Ether you need to relocate your wireless modem to acheive a stronger signal OR if your signal is strong on your adapters end, you could always upgrade to a different wireless adapter that can handle faster conections.
Intermittent or slow internet connection
Go here and upgrade your Router's Firmware - you will need to choose your location on the site at top left hand corner of the screen
http://www.linksysbycisco.com/UK/en/support
2answers
My internet is slow
Your internet connection speed may be faster as stated.
You may have a firewall blocking/filtering all traffic, that slows down your system. Disable or uninstall this firewall that could do some help.
also disable windows automatic updates. This creates more internet traffic.
If you can turn off automatic updates...it will make some difference.
The more RAM your system have, the more faster internet experience you will get.
 Grubhead
Grubhead
TUSHAR PANDYA
TUSHAR PANDYA
Level 1 Expert
Paul Bade
