Question about Jura Capresso Coffee Makers & Espresso Machines
My Jura Capresso is not processing the water instead it acts like the water is already been heated and added to the coffee grinds-what should I do
Posted by Ingrid Bialas Wilson on
Mia Taylor
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 46 Answers
Talk him
Posted on Jun 14, 2018
5 Related Answers
Anonymous
SOURCE: Jura Capresso Problem
check out this link:
http://www.kuntze.de/E/index.htm
Posted on Dec 30, 2007
Anonymous
  • 123 Answers
SOURCE: jura capresso E8
Did it work before this?
Sometimes hard water can build up and cause blockages.
Try mixing hot water and white vinegar (50/50 mix) and try running it through the machine. If this works, run it through a few more times than run cold water through a couple times to get rid of the vinegar.
Good Luck.
Posted on Apr 10, 2008
Anonymous
  • 6 Answers
SOURCE: My Jura Capresso C1300 reads Need Hot Water Cycle
*** in the pipes
Posted on Apr 15, 2009
Anonymous
  • 143 Answers
SOURCE: No steam on Capresso Impressa S8
Most likely problem is over temp cut out switch. Small diode attached to the boiler to prevent damage during boil dry, or fault in the heating element itself. Difficult machines to repair and best handled by a service technician.
Posted on Sep 14, 2009
Bob Keast
SOURCE: My Jura Capresso Impressa E8 is leaking water
I have the same problem with my E9 and I have traced it to the diaphragm unit that is just distal to the pump itself. Apparently, the diaphragm is secured with a steel band (not stainless since it is rusty) that may hold seals or O-rings that break down. You can observe it leaking when pressure applied during brewing. The question is: can a new unit be ordered and if so, where?
Posted on Nov 05, 2011
My Jura Impressa S9 does not GRIND?
Juani, can you use ground coffee in your machine. Then go and find the grinder and put some coffee beans in and grind them.
while enjoying your coffee read the user manual for the coffee machine and find out what the trouble is. If you can't find the manual, you can get it here Free User Manuals and Owners Guides ManualsOnline com
all the best Kolbrun
Jan 26, 2015 | Jura Capresso Impressa S9 Coffee...
Jura c9 on out of box start up won't leave rinse cycle and enter heating mode. Checked rotary dial but it seems fine.
You need to be patient and keep pressing the rinse button. I took a few water tanks of rinsing before it clicked over to heating mode. The manual and DVD need to mention this!
May 13, 2011 | Jura Capresso Capresso IMPRESSA C9 One...
I have problems with my jura capresso f60, it no longer makes coffee, it grinds the beans, but no liquid comes out. On the screen it says open tap, we have no idea how to fix this.
Machine thinks that there is no water getting to the machine. Majority of the time, this is caused by blockages of coffee in the brew group due to improper cleaning. I'm not saying that you haven't been cleaning it but that is usually the cause. How old is the machine? And has there been a cleaning tablet been put through it every day? Advise removing the brew group and check all pipes are clear, clean all loose coffee and check if you can blow through all of the pipes if you can loosen them. Clean coffee outlet/spout also. If the machines water is fed from a tank, It could also be a small bit of dirt has been pulled through. Hope this helps.
Mar 30, 2011 | Jura Capresso Jura-Capresso Impressa F60...
Makes grinding noise then Malfunction 8
Jura Capresso E8 Makes a cup of espresso then makes a gear grinding sound and then throughs an Error * on the screen. Machine was repaired by Capresso a year ago.
Oct 27, 2009 | Jura Capresso Impressa E8 Espresso/Coffee...
Sep 13, 2009 | Jura Capresso Impressa S8 Coffee Maker,...
Coffee Makers & Espresso Machines Logo
118 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
markybean
Level 1 Expert
ThaMp3Doctor
ThaMp3Doctor
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
