This one needs a little troubleshooting to narrow it down, but sounds like it could be your ignition coil or maybe the igniter. Both of these are located inside the distributor. For more ideas, and troubleshooting techniques, including pictures, check out tegger.com
Good luck, Mark
The honda either needs a spark plug or new spark plug socket
Sounds to me like an ignition coil or maybe the igniter. Both of these are located in the distributor.
Check tegger.com for some good information and pictures.
Mark
Car
not starting or turning over indicates towards multiple possibilities. It can
be issue with battery or weak battery. But if battery checks out ok, then it
can be starter issue or faulty alternator or problem with low fuel pressure or
no spark at spark plugs due to dirty spark plugs or faulty ignition
coil or injectors getting cracked or dirty and needs to be cleaned.
To
confirm the problem, the basic troubleshooting is required.
Click
this link below and follow the troubleshooting:------
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
This will help.
Thanks.
Did you check to make sure the timing belt hasn't broken?
