SOURCE: printing dots on Brother HL 4040CN
do this procedure
1.print test page then stop the printer on the middle print proses by turn the printer of or open the rear cover
2.remove the paper jam carefully
3.look to the paper if the problem found change the drum unit els the fusser unit cause the problem
SOURCE: 1 inch of left margin left even on the self test
Try using the "manual" width calibration. With the printer on, press and hold the green button. It will flash once, then twice, e.g. the sequence:
after the 5th flash, let go of the button. The printer will begin drawing rectangles which get wider and wider. Press the green button once (don't hold it) to indicate "when" the width is appropriate. However, I found the width was best calibrated when I let the printer draw rectangles right until the edge (where it automatically stops).
SOURCE: Left side of page cut off printing from Outlook 2003
Have you try to Copy paste the content of Outlook to Word and then try to print.
As Outlook have lesser option to set for printing. And may not possess all the features to print it correctly.
Let me know if I can assist you further.
Regards
Ellin
SOURCE: Always prints more to left than established margin
Check you Page Setup andmargin set. Sounds like the page isn't set up properly. When you typing a document, go to the FILE then PAGE SETUP. Margins and Paper Layout.
Hope this helps. Bud
