Question about La Crosse Measuring Tools & Sensors
My TX37-IT ia not working. I've put in new batteries but still no joy can you please help?
La Crosse Technology TX37-IT 04/2010 V45L1
Posted by David Gosling on
5 Related Answers
Anonymous
SOURCE: setting the altimeter on the la crosse xg-55
altitude changes depending on pressure; because you are along ocean, you experience it more than usual.
M problem is that temperature remains higher than normal one (30°C), can you solve it ?
Posted on Apr 04, 2009
sodeep
Sudeep Chatterjee
  • 3267 Answers
SOURCE: Display is fading
Check the batteries first before trying to tinker with the display. Also check for accumulation of fungus, if any, which can also cause the display to fade..............sodeep
Posted on Jul 24, 2009
Anonymous
SOURCE: Manual for La cross technology radoi controlled digital watch #wt
Downloaded instructions and working on it.
Thank you.
Bernard W. Goering
Posted on Sep 14, 2009
Anonymous
SOURCE: LA CROSSE RADIO CONTROLLED WATCH
How do I reset watch after changing battery?
Posted on Oct 11, 2009
homedesigner
Mark Tidwell
  • 583 Answers
SOURCE: We have an atomic clock with calendar and
Press and hold the SET key for 5 seconds. Press set key repeatedly until TZ is displayed on the bottom. Use the "+" key to set the time zone. -8 is for Pacific Time Zone, it will display -8 PST in the display. Press set to go to the DST setting, and so on until you've cycled through the options.
Posted on Feb 20, 2010
Why isn't outdoor temperature displayed on indoor unit?
I have a La Crosse unit right in front of me and it is showing +18 F tonight. Saturday, we are supposedly going to sub-zero.
With regard to your problem, La Crosse instructions are very specific about the battery replacement procedure. Remove all batteries from both units, then install new batteries in the outdoor unit. Allow time for the outdoor unit to "initialize" and begin sending temperature data. Install new batteries in the indoor unit and you should see the outdoor temperature displayed.
Feb 12, 2016 | La Crosse Technology Wireless Temperature...
How do I get a new outside temperature sensor?
You may have to order a replacement sensor directly from La Crosse.
Apr 29, 2015 | La Crosse Technology Lacrosse Technology...
My outside temperature and humidity sensor appears to have failed. I'd like to buy a replacement. 433 MHz. The system is WS-7395U. Please advise price. [email protected]
The WS-7395U uses the La Crosse TX8U outdoor temperature and humidity sensor. That part has a $49.99 MSRP. It is $46.95 from La Crosse; see http://www.lacrossetechnology.com/tx8/index.php to order the part. Other vendors that I checked do not have the sensor in stock for sale separately.
I hope this helps.
Aug 21, 2013 | La Crosse Technology La Crosse C86234...
Manual La crosse TX37-IT
station is not giving me an outside reading
Mar 31, 2013 | La Crosse Measuring Tools & Sensors
The rubber ******** my UV 100 is broken. Is it possible to find a new one. The watch is still working well
Hello michel_beauc
i think there's nothing you can do to change the rubber bracelete of your La Crosse UV 100 UV Watch. the best solution ever is to buy a new one. here is the online store offering a free delivery
List Price: $20.16 Deal Price: $18.99 Shipping: FREE buy.com offers La Crosse Technology UV Detection Watch for $18.99 + FREE shipping.
at buy.com Buy.com Coupons hope it helps
thanks for using fixya
May 02, 2011 | La Crosse UV 100 UV Watch
We now have two wall clocks that have stopped. Replacing batteries has not worked. Are they repairable? Can we get new or reconditioned movements?
Hello
Check its battery contacts for any rust or dust. Anyway clean it well and put the pattery, and check whether it is working or not.
Battery - The La Crosse Technology clock must have a fresh battery to receive and process the time signal.
Location - Try a different location, ideally near a window. It should be at least six feet from computers, TVs, air conditioners, other Radio-
Controlled clocks and other electrical appliances that cause interference.
Weather - Electrical storms between you and Colorado during the night will interfere with the WWVB signal.
Although we cannot control the weather we can help you predict it (see www.lacrossetechnology.com).
Daylight Savings Time
The National Institute of Standards and Technology and WWVB encode a special DST "bit" in the WWVB transmission for DST. Your La
Crosse Technology clock will read this information and automatically advance the hands one hour in the spring and eleven hours in the fall.
Arizona and Indiana
If you live in an area that does not recognize DST you must press the (unmarked) DST button for one second to deactivate your clock's DST
program. To reactivate the DST program simply press the DST button again for one second.
If you cant rectify the probelem, contact
La Crosse Technology, Ltd
2809 Losey Blvd. S.
La Crosse, WI 54601
Phone: 608.782.1610
Fax: 608.796.1020
or enter their website at
The device is a repairable one. OK.
Mar 14, 2011 | La Crosse Radio Controlled Atomic Clock
We have an Atomic Lacrosse WT-3143A clock; the battery ran out and a new one was put in. The hands rotated and stopped at 8 o'clock. We pushed ET buttons on the back and nothing happened, pushed the...
Directions:
http://www.klockit.com/PDFs/lacrossemanuals/AnalogWallClocks.pdf
For warranty work, technical support, or information contact:
2809 Losey Blvd. S.
La Crosse, WI 54601
Phone: 608.782.1610
Fax: 608.796.1020
e-mail:
[email protected] (warranty work)
[email protected] (information on other products)
web: www.lacrossetechnology.com
Sep 02, 2010 | La Crosse Radio Controlled Atomic Clock
It has a new battery now i can't reset the time it is a crane viceroy radio controlled fintan
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all LA CROSSE watch manuals. Rate me, please
Mar 30, 2010 | La Crosse Technology E. Howard Ambassador...
Measuring Tools & Sensors Logo
288 people viewed this question
Top La Crosse Measuring Tools & Sensors Experts
Marvin
Marvin
Ngoro
Are you a La Crosse Measuring Tool and Sensor Expert? Answer questions, earn points and help others
