Question about HP Televison & Video
What equipment do I need to connect my hp pavillion desktop pc570-p0xx computer to a directv hr54-700 dvr box to record to the computer and instructions on how and where to connect them? dragon11351
Posted by Rob Caucaucaus on
5 Related Answers
Anonymous
SOURCE: connecting HD cable box to DVR too HDTV
When I hooked up my HD cable box using an HDMI cable, I had to go into the cable screen menus and select HDMI output. You may have to do something similar when using an S-video cable. Your DVD recorder doesn't seem to have an HDMI input, so you'll have to use the S-video or (worst case) composite video (red, white, yellow cords). Your cable box may also be scrambling the signal so that you can't record. That may be why you can record by bypassing the cable box.
Posted on Jul 15, 2008
Anonymous
  • 26 Answers
SOURCE: how to restart hp pavillion 7965 desktop
Hi there. Try these steps:
1. On restart, press F8. This should bring you to a screen with various boot options.
2. Select "Last known good configuration". Windows then may load correctly.
3. If this doesn;t work, try the same thing. This time select "boot in Safe Mode". If Windows now loads in Safe Mode you should be able to restart and Windows may load correctly after this.
4. If these two both fail, you may have to repair Windows...
Posted on Jan 09, 2009
Anonymous
  • 86 Answers
SOURCE: My Directv DVR receiver will not stay on it is blinking yellow??
Unplug it from the power for about 30 minutes and then try again. If it still doesn't work I would call DirecTV and discuss getting it replaced.
Posted on Mar 19, 2009
Paul Hutchinson
  • 909 Answers
SOURCE: have magnavox dvd recorder record direcTV DVR programs w/ hdtv
I am unfamiliar with this unit.
If you have scart connecters on both, connect av2 on the tv to av in on the recorder. set the recorder to record from av source.
You should now record a program, I think the static is the fact that composite is out from the dvd only, not an input, and in on the tv, not an output.
Posted on Sep 04, 2009
Testimonial: "though unfamiliar with unit, pob-h tried to help solve my problem! that's more than i can say about my own husband! thanks for trying!"
tvtek
Duke
  • 1284 Answers
SOURCE: Philips DSR708 DirecTV DVR hangs up after power up
Is this a new issue that has shown up on the receiver? If so then you might have a bad hard drive in the receiver causing it to hang on boot up. Also these units require two inputs from the satellite antenna so that could be another possibility.
Posted on Nov 17, 2009
Need helping hooking up to my existing directv box
About 409,000 results (0.52 seconds) Search Results
    DIRECTV GenieĀ® WiFi Setup & Connection ' DIRECTV ...
    https://support.directv.com/.../directv-genie%26reg%3B-wifi-set...
    DirecTVWatch this video to learn how to connect your GenieĀ® HD DVR model HR44 to the Internet. Follow the simple ... No, my router does NOT have WPS or I want to configuremy router manually. Image .... Order DIRECTV Existing... Still need help?
    Do I need additional equipment to connect more than one TV
    https://support.directv.com/app/answers/detail/a_id/3945
    DirecTVYou need one Genie Mini or Wireless Genie Mini for each additional TV. ... So in a Genie Whole-Home HD DVR setup, one of your TVs is directly ... which allowsDIRECTV Ready TVs to be connected to the Genie HD DVR as additional TVs in your setup without a Genie Mini. ... Order DIRECTV Existing. ... Still need help?
    How to Connect DIRECTV Receiver to TV ' DIRECTV Support
    https://support.directv.com/.../how-to-connect-directv-receiver-t...
    DirecTVHow do I connect my DIRECTV receiver or Genie Mini to my TV? ... This will help you determine what cable to use. .... To download and print them, you'll need.
    My equipment was shipped to me. How do I install it ...
    https://support.directv.com/app/answers/detail/a_id/4267
    DirecTV
Feb 08, 2016 | Televison & Video
DVR-R10 stops recording with 10-15 mins left
If it's your cable box DVR, you need to call your cable provider to reset your cable box.
Apr 16, 2014 | Directv R10 TV Receivers and DVRs
Nov 17, 2009 | Philips DSR708 DirecTV DTV Receiver /...
How do i record from directv hddvr plus to my vcr or dvd
Your going to need a AV connection out of the DVR into the DVD or VCR, whichever you want to record to. Go with the highest quality cable you can because that will define the quality you end up with. If you have an HDMI connection out of the DVR and an HDMI connection into your DVD Recorder, that is definitally the way to go.
Oct 25, 2009 | Directv Plus DVR DTV Receiver / 100-Hours...
Have magnavox dvd recorder record direcTV DVR programs w/ hdtv
Sep 04, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Want to run my dtv receiver through new digital converter box.
You will not be able to record local station from a DTV converter connected thru a directv receiver unless there is a a/v input on the directv samsung receiver. Also check the user manual for this receiver if recording from an external source such as a DTV converter box is possible. The answer to seperating the DTV converter box from the directv samsung receiver is possible if your tv has multiple inputs. Try connecting the DTV box to the RF input and the directv samsung box to an a/v input then change inputs using the tv remote. you will need an av cable (yellow/ red/white) for the directv box and a rf jumper cable for the DTV box.
May 17, 2009 | Samsung SIR-S4040R DirecTV DTV Receiver /...
Our Dvr will only record on the channel we are watching. I cannot watch one show and record another? It says I have to be watching the channel I want to record?
for the dual tuner, if you are unsure what this is... please look at the back of the satellite box and see if you have 2 sat in cables. if you do, then you need to reprogram your satellite. if you do not have 2 sat in cables then you would need to contact dtv to get this installed.
Mar 29, 2009 | Directv (R10) DTV Receiver / 70-Hours...
Can hughes sd-dvr 80 be used as stand-alone dvr?
not without a subscription to Directv. after it enters the box it is basicly a Directv signal, it has to show up on the program guide.
Mar 10, 2009 | Hughes SD-DVR80 DirecTV / TiVo DTV...
Help!
Unplug the unit> Remove> Take out to back yard> Smash repeatedly with a sledge hammer of at least 2Lbs> Mail the resulting material to cable company preferably next-day.
Apr 24, 2008 | Directv Plus DVR DTV Receiver / 100-Hours...
Direct TV DVR "skipping" like a dvd
You have an internal hard drive error. You will need a new box.
Jan 22, 2008 | Directv Plus DVR DTV Receiver / 100-Hours...
Televison & Video Logo
Top HP Televison & Video Experts
Edward Easley
Edward Easley
Bernie Scott
Level 1 Expert
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
