Question about Vision Televison & Video
Finding rear vision module - Vision Televison & Video
Posted by Timothy Cook on
I NEED HELP FINDING VISION ON MY PHONE TO FINISH THE SET UP PROCESS
If you have a iphone you go to your settings. Then you click on general, Then you scroll down to accessibility and vision should be the first thing on the screen.
Sep 10, 2017 | Cell Phones
My rear view mirror camera quit working I checked the fuse it's good the backup lights work.Help
Circuit/System Description
When the transmission is placed into REVERSE, a 12 volt signal is sent to the rearview camera image display module indicating that camera operation is requested. The rearview camera image display module then supplies ignition voltage and ground to the rear vision camera. The rear vision camera sends video information through the rearview camera image display module to the inside rearview mirror through a video signal + and a video signal - circuit. A grounded shielding also wraps the video signal circuits to reduce electronic interference which may degrade the video signal and cause a distorted or otherwise degraded image.
Rearview Camera Image Display Module (UVC)
In the instrument panel behind the driver side knee bolster to the right of the steering column
Do you know how to do electrical testing ?
Rear Vision Camera System Does Not Display
Ignition OFF, disconnect the harness connector at the rear view camera image display module.
Test for less than 1.0 ohm between the ground circuit terminal 3 and ground.
? If greater than the specified range, test the ground circuit for an open/high resistance.
Ignition ON, verify that a test lamp illuminates between the ignition circuit terminal 2 and ground.
? If the test lamp does not illuminate, test the ignition circuit for a short to ground or an open/high resistance.
Ignition ON, park brake applied, vehicle in REVERSE, verify that a test lamp illuminates between the control circuit terminal 1 and ground.
? If the test lamp does not illuminate, test the control circuit for a short to ground or an open/high resistance. If the circuit tests normal, replace the BCM.
Ignition OFF, connect the harness connector at the rear view camera image display module. Disconnect the harness connector at the rearview camera.
Ignition OFF, test for less than 1.0 ohm between the ground circuit terminal B and ground.
? If greater than the specified range, test the ground circuit for an open/high resistance. If the circuit tests normal, replace the rear view camera image display module.
Ignition ON, park brake applied, vehicle in REVERSE, test for 5.8-6.2 volts between the 6-volt reference circuit terminal A and ground.
? If less than the specified range, test the 6-volt reference circuit for a short to ground or an open/high resistance. If the circuit tests normal, replace the rear view camera image display module.
? If greater than the specified range, test the 6-volt reference circuit for a short to voltage. If the circuit tests normal, replace the rear view camera image display module.
Test for less then 1 ohm between the shield ground circuit terminal 10 at the rear vision camera display module harness connector and terminal D at the rear vision camera harness connector.
? If greater than the specified range, test the shield ground circuit for an open/high resistance.
Ignition ON, test for less than 1 volt between the signal circuit terminal 9 and ground.
? If greater than the specified range, test the signal circuit for a short to voltage.
Test for infinite resistance between the signal circuit terminal 9 and ground.
? If not the specified value, test the signal circuit for a short to ground.
Test for less then 1 ohm between the signal circuit terminal 9 at the rear vision camera display module harness connector and terminal C at the rear vision camera harness connector.
? If greater than the specified range, test the signal circuit for an open/high resistance.
Ignition OFF, disconnect the harness connector at the inside rearview mirror.
Ignition ON, test for less than 1 volt between the following signal circuits at the inside rearview mirror harness connector and ground:
• Video + signal circuit terminal 6
• Video - signal circuit terminal 7
Test for infinite resistance between the following signal circuits at the inside rearview mirror harness connector and ground:
? If greater than the specified value, test the signal circuit for a short to ground.
Test for less then 1 ohm between the following signal circuits:
• Signal circuit terminal 12 at the rearview camera image module and terminal 6 at the inside rearview mirror.
• Signal circuit terminal 11 at the rearview camera image module and terminal 7 at the inside rearview mirror.
If all circuits test normal, test or replace the rear vision camera.
Ignition ON, park brake applied, vehicle in REVERSE, verify a clear rear vision image is displayed on the radio.
? If a clear rear vision image is not displayed, test or replace the inside rearview mirror
Feb 21, 2016 | 2009 Hummer H3
Code P2135 Kia sedona 2008
- Faulty Throttle Position Sensor (TPS )
- Throttle Position Sensor (TPS ) harness is open or shorted
- Throttle Position Sensor (TPS ) circuit poor electrical connection
- Faulty Powertrain Control Module (PCM)
Oct 26, 2014 | Gentex 2008 Kia Sedona - All Sedona models...
97 ford windstar has no power to the tail lig hts, the fuses have been check and are in good condition. Where are the relay switch es located ?
Your Windstar's tail lights are controlled by the Rear Control Module. Failure of the rear module is common. You can find the module just inside the liftgate on the right (passenger) side of the vehicle. Remove he cover for the jack equipment in the right quarter trim panel and look inside. You will see the module in there. I hae had some luck finding good used modules in the salvage yard. (Definitely NOT one of Ford's better ideas!)
May 01, 2011 | 1997 Ford Windstar
Samsung hcm5525w rear projection tv
Extensive analysis revealed this unit to be for 120V 60Hz regions. If you use it in a region where the mains supply is 220/240V 50Hz then it won't work. In addition, the PSU will overheat, with possible damage to other modules.
One possible solution is a 120V 60Hz inverter, else Samsung may be able to provide the correct PSU for 220/240V.
Jul 14, 2008 | Samsung HCM5525W 55" Rear Projection...
53UDX10B 53 in. Rear Projection "3D vision"
I had the same problem with the same model earlier this year. You need to have the convergence module replaced on a circuit board inside. Expect to pay $400-$500 to a qualified repair shop.
Oct 11, 2007 | Hitachi 53UDX10B 53" Rear Projection...
RCA Home Theatre Model # P56927, Serial # 026451246
your convergence alignment is off,requires reaignment or possible replacement of module,this type of rca projection tv has a fault with the harness feeding the convergence module there is a fix for it,contact you local rca dealer,they must replace the connector because it bows and looses connection over time that creates other faults also/
Aug 22, 2007 | RCA P52926 52" Rear Projection Television
Televison & Video Logo
Top Vision Televison & Video Experts
Marvin
Marvin
ray gallant
Are you a Vision Televison and Video Expert? Answer questions, earn points and help others
