Question about Kohler Electrical Supplies
How do I adjust the valves on a 15ohv Kohler command
Posted by POLLY HANGARTNER on
2 Related Answers
Sam
  • 3247 Answers
SOURCE: how to adjust the valves on a Kohler command 13 engine on a Husqvarna
The service manuals for the Kohler engines are available here.
Kohler Engines CH13 Command PRO Product Detail Engines
Posted on Sep 14, 2014
Richard Leister
  • 70 Answers
SOURCE: kohler Command 14. Why is oil mixing w gas and blowing out valve cover breather?
Check vent tube is connected on OHV Cover . Check for leak around valve cover hissing or mist could be head gasket also
If you need further help, reach me via phone at https://www.6ya.com/expert/richard_b70d968cd1a1d293
Posted on Apr 18, 2016
25hp kohler hot start problem. Replaced fuel filter, plugs and cleaned air filter - same problem. it won'd restart when hot.
3 possibles come to mind
fuel vaporization in the line to the carby or in the carby bowl (check float level adjustment)
valves are being held open when hot--- valve stem lengths increase reducing tappet clearance___adjust valves when hot
check coil/ ignition module for failure when hot as they can open circuit ./ short circuit when internal components fail from heat
Sep 27, 2016 | Kohler Command V-Twin Horizontal Engine...
Kohler Command 14 lawnmower. Why is oil mixing with gas and blowing out valve cover breather?
sounds like the valves are out of adjustment or the pvc filter is plugged..
Apr 17, 2016 | Garden
Why oil consumption on kohler command 20
Either badly seated oil rings or PVC valve is stuck open allowing oil to enter through carburetor.
Oct 20, 2014 | Kohler Command OHV Horizontal Engine with...
How to adjust the valves on a Kohler command 13 CV16s
you need a valve job done and valves replaced you have to take in maybe carb rebuilt to valve job 100.00 per cylinder carb rebuilt 80.00
Sep 14, 2014 | Garden
Why is motor not running now?
It sounds like you made a bad valve adjustment and it has thrown a rod, and binding on one cylinder, hence partial turnover, cylinder on compression. Pull apart again and re-check.
Jun 02, 2013 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Valve clearances
mine has hydrodrolic lifters no adjustmetn
Aug 21, 2012 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Hello, I need to know how to adjust engine timing for Kohler Command, 22hp engine, manufactered in 2007 on a Cub Cadet 2544 Heavy Duty tractor. Thanx, Rick
If you have what i think you have. The only timing adjustment as such would be in the coil to magnet air gas. Which is usually around .125 thou.
The other timing is done internally, when you line up the marks on the cam gear with the marks on the crank gear. good luck and be careful
Sep 21, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Kohler motor starts then carb loads up with gas
If the engine is running rough then this could mean that you have weak spark or valve adjustment. When an engine runs rough it will not burn all the fuel, which will create excess fuel in the air cleaner housing. Also, make sure the the float is closing in the carberator.
May 01, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Electrical Supplies Logo
46 people viewed this question
Top Kohler Electrical Supplies Experts
John Trevino
Tim Venetis
jdthefixer
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
