The best solution you'll get from books at www.reliable-store.com
These are books containing info on repair, service, troubleshooting, parts info, assembling dissemble, removal, error/fault codes, wiring diagrams and everything on any vehicles cars, atv, trucks. forklifts, boats, excavators etc
SOURCE: the rear wiper workes if
Hi You may want to check one thing. Roll the rear window down a few inches and then rolll it back up. There must be a relay switch to tell the car the window is open. If that does not work, it might be the relay switch. There are three possible points of failure; the motor, the parking switch, and finally the switch that turns it on. Please get back to us if you have further query else please accept the suggestion.
Obviously, the motor is located in the hatch itself but also there will be a parking switch that supplies power to the motor after the user switch is turned off and until the blade is in the park position. The user switch is of course located on the dash or in a stalk on the steering column. Check for voltage with a multimeter at the motor and/or continuity of it. You should be able to eliminate the items that are working in 20 or 30 minutes.
Thank you for contacting fixya.com
SOURCE: I have a 93 land cruiser that won't start. The
Did you try jumping it off with another car?? It sounds like it may have a loose ground cable. make sure the battery is good, make sure the cable ends are clean and tight, check ground cable on engine block. Hope this helps you...
