Question about JVC Computers & Internet
My Jvc smart tv won't connect wireless to my router .
Haven't used for a while but do I delete router and can I start a gain
Posted by Wendy Reynolds on
kris gums
    Habit-Forming:
    New Friend:
  • 15 Answers
Yeah you can delete it again and configure the way your did it before but if you don't know how to connect using the router back again to your Jvc smart tv then ask guidance to experts
Posted on Jun 11, 2018
5 Related Answers
Dave Byrne
  • 58 Answers
SOURCE: How can i unlock netopia 2247NWG
Firstly... avoid showing your SSID (eircom-123456789) here, as the WEP key can be reverse engineered from the SSID.
To change your SSID, connect your router to your PC with an ethernet cable, go to your web browser (Intenet Explorer, Forefox, etc) and type 192.168.1.254, and press return.
This will open the control panel for the router.
Select 'EXPERT MODE' from the menu on the right, and accept the warning prompt. Then click on 'CONNECTION' and the 'WIRELESS' on the menu on the right.
In the main window you can then change the SSID for your network.
You can also change some of the other options in this window such as enabling closed mode, change security protocol, password, etc.
Posted on May 10, 2008
Dave Byrne
  • 58 Answers
SOURCE: how can i unlock my router?
Anonymous
  • 287 Answers
SOURCE: edimax wireless-g broadband router
please confirm if the router is a 6104K, or a KP or Wg or another model as the K and KP are not wireless, a "W" will denote wireless capability...
Not all manuals are available for download from the Edimax website but heres a start...
Connect the router to your PC with a cable... leave the modem disconnected to start with
open internet explorer and type in enter the default IP address 192.168.2.1 (broadband router’s IP address) into your PC’s web browser and press <enter>
This should bring up a user/password dialog box. By default the user name is "admin" and the password is "1234".
Confirm you are getting this far and we'll go the next steps
Posted on Jul 06, 2008
Gale Todd
  • 1116 Answers
SOURCE: I have both my iMac & Samsung Smart TV
There's an adapter that monoprice.com just brought out that I purchased. Works like a charm. It still plugs into the mini display port but it also has a usb connector that you must plug into one of your usb ports on your imac. This allows for the audio to travel over the hdmi with the video. The link is below.
http://www.monoprice.com/products/product.asp?cid=104&cp_id=10428&cs_id=1042802&pid=5969&seq=1&format=2
Be aware that once you add the TV as a second screen that it extends your desktop typically to the right of your current one. Just drag an open window to the right and it appears on your TV. The resolution of the TV is probably lower than the mac screen so the extension is a different size. You can move the extension around to the top/bottom/left/right etc.
You can see this in Preferences - displays - arrangement, After you have added your second screen.
If you don't want to extend the desktop but would rather mirror your primary display, this is where you check "mirror displays"
Posted on Jul 30, 2011
maxcarson
max carson
  • 7627 Answers
SOURCE: can't connect vizio smart tv with belkin n750 dual band router
In your TV's menu there should be a wireless setup. You didn't supply the Model of the TV. Here's a manual for a Vizio: http://store.vizio.com/documents/downloads/hdtv/M3D650SV/1185QSG_M3D650SV_B.pdf
Posted on Dec 10, 2012
The wireless network security settings on laptop do not match settings on router?
Hello.
- This error occurs when the wireless security that you set on the wireless laptop does not match the wireless security on the router.
  • If the wireless router's security setting is WPA but on the laptop you used WEP for the wireless security, that's when a mismatch occurs.
- What you can do to resolve the problem is to delete the wireless profile you created on the laptop. After that, let the laptop search for wireless connection available, select the correct wireless settings and it should connect.
--For example the operating system of your computer is Vista, in order to remove the wireless profile you created and reconnect to the wireless router, do the following instructions:- Go to Start>Control Panel>Network and Internet> Network and Sharing Center- Click on Manage Wireless Networks on the left panel. Delete the wireless profile then Search for available wireless networks again. Type the correct wireless security settings on your laptop
-- If you would like to know what wireless security has been setup on the router, connect the laptop or use a desktop which is wired to the router then access the router setup page by typing http://www.routerlogin.net or 192.168.1.1 in the address field of your browser and then press Enter. Enter admin for the router user name and your password (or the default, password).
--After logging in. In the main menu on the left, click on Wireless Settings, from there you can check the wireless security or you can setup wireless security from there if you haven't done so.
Hope this helps. Have a nice day. Don't forget to vote if you find this guide helpful. Thanks.
Nov 26, 2011 | NetGear WNR2000 Wireless Router
How do i unlock my d link
The first thing you should do upon completing a wireless connection with a D-Link router is to set up wireless security by accessing the router settings. This protects you against computer hackers trying to gain access to your bandwidth to commit fraud against you or others. It also restricts access away from those who live around you that would rather use your bandwidth instead of paying for their own. Unauthorized users can drastically slow your network speed.
1.Enter the IP address for the D-Link router into a web browser. The default address is 192.168.0.1. This address is typically located underneath the router. Load the page to access the login details.
2.Enter the login details. Refer to your records if necessary. The user name is usually "admin." Enter in your password. A blank password is the default. Load the page to access the router settings. Note: It's important to set a password, if you haven't already done so.
3.Click on the "Set Up" hyperlink and then click on the "Wireless Settings" hyperlink.
4.Scroll down until you see "Wireless Security Mode" and select your desired level of security from the drop-down. The type of security you select depends on the electronic equipment you want to connect to your network and the level of security you want to enable. See Resources for details on the different types of security available. If you are still unsure, WEP offers a decent level of security and works with almost all Wi-Fi enabled components like mobile phones, gaming equipment and laptops.
5.Enter in your desired password into the "Password" field and then enter in the password a second time in the "Re-Enter Password" field. Select "Save Setting" to enable wireless security on your D-Link Router.
Sep 20, 2011 | D-Link DIR-300 Wireless Router
Very low volume from mic input even with Gain and Master turned full on
You haven't told us what type mic you are using. If you are trying to use a condensr mic with this, you will need a preamp that supplies Phantom power to the mic. You haven't told us what cable you are using. Do check that you aren't using a condenser mic as there will be virtually no volume.
Aug 31, 2011 | Fishman Loudbox Mini Acoustic Amplifier...
I use yahoo mail, and when I was checking my e-mails this morning I realized that all my previous e-mails in my inbox has gone. I haven't done any adjustment or delete them by accident
unfortunately this happens from time to time, you need to contact yahoo support but they will only look for emails that have disappeared within the last 2 days. they've lost my emails covering a 4 year period!! use a mail program like thunderbird to download the emails to your pc - note: only the inbox is downloaded
May 30, 2011 | Computers & Internet
How do I strengthen my wireless signal? I am using a Linksys router.
The easiest is to replace the small antenna with a higher gain one. You get some very effective 8+ db gain omni directional antennas for linksys on ebay, amazon etc.
If you are in one direction you can also use a Yagi antenna (Directional) with high gain (20+db gain)
Normally the problem is not just the router, but the connecting device as well.
Keeping in mind you have 2 way comms between 2 devices. The router and say a laptop. ideally you should upgrade both antennas. As the best antenna on an Linksys AP will not fix a weak laptop signal. (it will transmit better, and receive better, but the laptop should also transmit and receive better)
Hope it helps
Wilhelm
Mar 29, 2011 | Linksys Wireless-G Broadband Router
I JUST MOVED AND NEED HELP HOW TO RESET MY NETGEAR WGR614V9 WIRELESS ROUTER. WHAT DO I DO TO RESET MY PASSWORD TOO I THINK. thank you
Turn the router over and check the defaults on the bottom of the router. try the default admin and password to see if you can gain access to the router. Most people use the defaults so this might be a good way of gaining access. Otherwise there is usually a reset switch on the back or front of the router. You wil need a paper-clip[ to reset the switch. then you can use the defaults to gain access and reconfigure the router.
Jan 14, 2011 | NetGear WGR614 Wireless Router
I have a Philips Wireless Router SNA5630NS/05
Go fix your portting settings in your router.
Now do you want to gain access the laptop by loggin into it?
If so, go to VNC.com and download one of them. (Virtual Network Computer) You will have to install VNC on both computers. Then use VNC viewer to witre the ip of your laptop. Then press enter, you should gain access to your laptop wirelessly.
But you have to do portforwarding in the router and other small stuffs to make ths work.
Feb 12, 2008 | Computers & Internet
I've deleted my Nvidia for my Belkin router
A friend who knows a fair bit about computers came over and worked out that it was the NForce software that I needed. We downloaded it and the computer is working now. Thanks for your help anyway - and you were right.
Feb 01, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Computers & Internet Logo
2,243 people viewed this question
Top JVC Computers & Internet Experts
Marvin
Marvin
Davit Mamyan
Davit Mamyan
Jim Pattison
Are you a JVC Computer and Internet Expert? Answer questions, earn points and help others
