Question about Golf
I put New batteries in my 1999 club car and now I got no power going up hills and if I leave it for awhile the battery light comes on
Posted by Robert roache on
5 Related Answers
Benimur
Louie Role
  • 6966 Answers
SOURCE: 2002 Hyundai Accent lost power
Hi and welcome to FixYa,
Offhand, definitely an electrical issue. Some ideas to check, consider and/or explore:
  • IGN switch - check for loose, corroded or heating connections. To test, under normal usage of the vehicle, should feel warm but not overly hot. If so, then possibly loose connection;
  • fuse/relay box - check for loose, corroded or burned terminals, holders, clips and connectors/pins. Use an electrical contact cleaner and spray. It may also be necessary to scrape to remove burnt marks/corrosion;
  • fusible link - the battery would have 2 wires connected to the + terminal. The big wire goes to the starter, the smaller of the two is the electrical systems main wire. This normally goes to the fuse/relay box. Check for frayed ends, loose connection, corroded terminals. In some instances instead of being at the battery's + terminal, it is connected to the end of the big cable down at the starter motor.
  • ALL connectors with big wires - these carry the main +12 either as always ON, ACC or IGN. If a connector has a wire bigger than the others, check them. It may be necessary to disconnect to enable you access to the inside pins/terminals. Scrape them clean.
Good luck and Thank you for using FixYa.
Posted on Dec 29, 2008
tony tiler
  • 45 Answers
try making sure all belts are tight jode
Anonymous
  • 5 Answers
SOURCE: 1999 legacy outback no power going up hill,new knock sensor
Check your tail pipe for color. If insides are black you are running rich and it all may boil down to an oxygen sensor or an EGR valve. EGR valves are the most common causes for the 'check engine' light to come on. Your trouble codes will tell you what it is. Some auto stores will check it for free or you can buy an inexpensive checker.
Posted on Mar 12, 2009
Anonymous
  • 184 Answers
SOURCE: outback wagon no power going up hills.
What's the check engine light code? You need to get the code(s) read using a code reader and then we can help. A place like AutoZone will read the code for free and then you can look it up at http://www.obd-codes.com/trouble_codes/
Posted on Mar 14, 2009
Efstathios Govas
  • 285 Answers
SOURCE: red battery warning light came on,
this light means there is a problem with your charging system not your battery,the alternator is the culprit here,hope this helps
Posted on Sep 15, 2009
BEVERLYHILLS POLO CLUB WATCH MEN
Put a screw driver in the hole on the clasp. It shouls flip up and then you can slide the clasp up and down the watch band.
Dec 26, 2012 | Watches
1999 ford mustang. theft light blinks car will not start. put new battery. work f
maybe not a full time drain,sometimes alternators will work off and on...have it checked under load,at a shop.
Nov 28, 2012 | Cars & Trucks
1999 audi a6 wont crank sometimes
Either there is a bad or dirty battery connection which is allowing the lights but no crank or you could have dirty or loose starter wires or starter relay may be bad or ignition is a possibility. All these can be tested with an ohmmeter for power. I would start with connections
Jun 04, 2012 | Audi A6 Cars & Trucks
Batery light would come on when accelerating up to freeway speed or when going over a big hill and head lights would dim. Mechanic said alt/gen/bat all good, car still seemed to drive fine otherwise....
the voltage regulator is bad inside the alternator. it seems to be getting hot and kicking off the charging system. the last time it has drained your battery.
Aug 13, 2011 | 1999 Mercury Sable
Won't start
I would try the battery, it sounds like it has enough juice to power the lights, but not everything else. You can take the battery to a local parts store and they can test it at no charge.
Oct 04, 2009 | 1999 Pontiac Sunfire
I have a 99 camry the battery went dead and i jumped it the lights come on but its not getting no power to the egnition no dash lights no fire
If your battery 'went dead' your probably have had a battery problem for awhile. Put in a new battery AND make sure the alternator is putting out 14-15volts. You can do this yourself. Buy or borrow a voltmeter-or DVOM-connect the black to the neg, and the red to the pos. while its running and make sure you have the 14-15 volts. Anything under this voltage is probably and indication that your alternator is needed also.
Sep 04, 2009 | 1999 Toyota Camry
Need a schematic for a club car golf cart
new batteries-36 volts--can,t get power to motor------ help please
Apr 23, 2009 | 3d Rose Londons Times Funny Cow Cartoons -...
Battery, O2 sensor, transmission miss fire
change O2 sensor as we all breathe air,Now battery ?? try disconnecting it ,then with nothing on touch battery lead too terminal and see if you get a spark ?? no spark then battery cells shorting out across the plates caused by sulphation ,,cure put battery on a small charger for about a week to try to de sulphate the plates.Small discharge when touching lead to terminal then a boot light is on or an alarm system.Another trick is to discinnect the big wire on the back of the altenator and leave car for three days to see if goes flat as a dodgy diode in the rectifier will give the same fault.
Jan 07, 2009 | 1999 Chevrolet Lumina
Golf Logo
226 people viewed this question
Top Golf Experts
FastHarley
FastHarley
ray gallant
Kardoc
Are you a Golf Expert? Answer questions, earn points and help others
