Question about Connex Radio Communications
My connex 3400hp gets out and receives you can hear static then you can't then you key up the mic and you hear static again
Posted by Tim holt on
5 Related Answers
Gavin93
EDACS
  • 66 Answers
SOURCE: connex 3300 c.b radio
The Connex radio is a division of Cobra, and no offense, but Cobras are one of the cheapest radios around. The problem with your Connex is a simple receiver malfunction. The receiver probably worked great until it was put into storage for a long time, you can replace the receiver, or you can fiddle around with the receive gain until you hear something. But you may just want to send it to a radio store and have it looked at, to be honest with you, Connex is a terrible radio, they sound good, but they're terrible radios. Go with Galaxy or Uniden radios, you won't be disappointed.
Posted on Jul 02, 2008
Anonymous
  • 14 Answers
SOURCE: connex 3300hp
Poor ground shield, or poor solder joint in mic cable.
Posted on Nov 05, 2008
kb8dns
Rod Wallberg
  • 494 Answers
SOURCE: i just purchased a connex 3400hp and my cb freinds
The Cobra 29 has always been a good talking radio and is preferred by truck driver mainly for that reason! The Connex is a great radio in it's own right but sometimes needs a little help. I would suggest a power mic and there are many to choose from but Astatic is a clear winner! My two cents for a suggestion!
Posted on Mar 07, 2010
Mister 44
Jim Verge
  • 35 Answers
SOURCE: connex 4600 turbo radio stays keyed up even with
Bad RX/TX Transistor? I don't have a diagram for the 4600. Sorry!
Posted on Apr 03, 2010
anymhz
AnyMHz.com
  • 500 Answers
SOURCE: after you convert the connex 3400hp from ham to
you will need a frequency counter, to show the channels. 1-40 and the others are allocated as frequencies. there are lists available showing ch1 band A is ??? so forth. there shouldn't be uppers or lower on it its just a AM/FM only radio NO SSB.
and these ARE NOT AMATEUR / HAM radios!!!!!!! these are EXPORTS...
Posted on Dec 16, 2010
I want to peak and tune my connex 3400hp
people think that if they peak and tune a radio it will work better. First, if its brand new from the factory you shouldn't have to,all you should have to do is lower the dead key raise the modulation and you are good to go . The proper way to do this is with a spectrom analyzer . Do you have one? Cheap on ebay ,may 4000-5000 dollars but if you get one and set that radio perfect you should hear anyone complain that you are interfering with their radio.
Sep 05, 2016 | Connex Radio Communications
I have a Connex 3400hp and it just topped receiving all of a sudden while driving down the road
did you check to see if it was still plugged in.maybe the reverse polarity diode or a crack in the pcb
Feb 16, 2014 | Connex Radio Communications
Converting 10 meter to 11 meter on Connex CX-3400HP CB RADIO
Turn the mode switch to the setting you want and leave it there .
Jan 10, 2014 | Connex CX-3400hp AM/FM 10 Meter Amateur...
I have a connex cx-3400HP d and a r not working until the unit get's hot
Take it to a good cb shop radioactiveradios do really good work on connex radios
May 27, 2012 | Connex CX-4300HP CB Radio
I just purchased a connex 3400hp and my cb freinds tell me that my other radio sounds better than the cx 3400hp,my other radio is a cobra 29 ltd classic.my 29 has more audio and modulation and both radios...
Mar 07, 2010 | Connex 3300 240-Channels Base CB Radio
Connex 3300hp
Oct 07, 2008 | Connex 3300 240-Channels Base CB Radio
Connex 3300 c.b radio
Jun 30, 2008 | Connex 3300 240-Channels Base CB Radio
Radio Communications Logo
60 people viewed this question
Top Connex Radio Communications Experts
Tony Raia
Marvin
Marvin
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
