Question about Golf
I have a 2009 Yamaha electric golf cart. It is fully charged. Starts off fast but slows down tremendously. Help?
Posted by Linda on
john h
    Top Expert:
  • 23,523 Answers
Test and check the batteries one or more failing
Posted on Jun 10, 2018
Testimonial: "I have read also it could be some kind of switch? Also I have been told they need to have a deep charge sometimes. Is this true? The batteries are only 3 years old"
5 Related Answers
Anonymous
  • 161 Answers
SOURCE: trickle charger for storing electric cushman golf cart
contact manufacturer, and seek there advice
Posted on Nov 27, 2008
Anonymous
SOURCE: 1982 e-z go electric golf cart needteck sheet.
I have a 96 EZ GO gas golf cart with loose steering. What parts are normally needed to correct this problem and are special tools required for me to replace the parts.
Thanks,
Bob
Posted on Jan 22, 2009
Anonymous
  • 474 Answers
SOURCE: making golf carts faster
if its gas remove govener sping and hook up throttle cable directly to carb. be forwarned that these are not designed for high end speed and it will be squirly. also a lot of parts will wear faster including the engine.i suggest increasing the govenor spring tension by either bendig the bracket a hair or finding a little stiffer spring
Posted on Sep 16, 2009
Anonymous
  • 166 Answers
SOURCE: Electric Golf cart only shutters and inches forward
so many possibilities...
does it roll fairly freely? (checking to see if the brakes or rearend seized up)
Are there any "bad" sounds like things grinding? (Connection between Motor and rearend, axle splines...)
If all that is solid, it is likely in the controller.... (it takes a solid charge right... No bad batteries in there or loose connection? might want to check all the battery connections to make sure none are burnt...)
1997.. does it have the electonic speed control by that year? the other possibilty is that the accelerator is not working corectly. they used a resistor system on old ones that has contactors that would get worn out.... Newer ones control a potentiometer(sp) that controlled the speed.
Only a few real components to check, but if you are not mechanically and electically inclined, could be tough to isolate.
peace,
Posted on Mar 07, 2010
Joe H.
  • 330 Answers
SOURCE: electric golf cart won't go forward nor backwards.
check key switch, and fuses.set brake before putting it in gear.The relay diods that controll power may have a wire off.
Posted on Apr 21, 2010
I have a 2010 yamaha golf cart,has brand new batteries,and the batteries drain by nine holes,is it the voltage regulator? or something else
Make sure the batteries are fully charged. if your cart has it's own charger it may not fully charge. I would purchase a portable one and make sure they fully charge then you would know whether the cart charger is working.
Nov 05, 2017 | Golf
Charger wont kick off after fully charged.
Charger won't shut off - Buggies Gone Wild Golf Cart Forum
www.buggiesgonewild.com > ... > Electric Club Car
Sep 27, 2010 - 7 posts - ‎2 authors
But the cart still wouldn't fully charge. After charging the cart, I checked the voltage on the entire battery pack using my meter and then each ... 36 volt powerwise ez go charger not working
Sep 5, 2011
Club car 96 battery charger not turning off
Aug 30, 2011
2001 Club Car Charger Won't kick off
May 31, 2011
48v club car charger wont shut off
Apr 11, 2009
More results from www.buggiesgonewild.com
About Golf Cart Battery Chargers - Golf Cart TalkGolf Cart Talk
www.golfcarcatalog.com/golf-cart-blog/about-golf-cart-battery-chargers/
Jan 24, 2016 | Golf
I bought a 2010 zone electric cart and it will not run but about 20 minutes on a full charge can anyone help Please
Check the battery for voltage. May be shot and won't fully charge even though it says it is.
Dec 26, 2014 | Golf
Where is the fuse for the headlights located on a 2009 Yamaha electric golf cart?
Go on BING images. Put in Yamaha Golf Cart diagram, and all sorts of info pops up.
Nov 15, 2014 | Motorcycles
Golf Logo
456 people viewed this question
Top Golf Experts
ray gallant
Tom Chichester
Kardoc
Are you a Golf Expert? Answer questions, earn points and help others
