Question about LG Refrigerators
LG fridge lmx 25964st/2 not cooling, the led trouble light flashes 6x. please help
Posted by Heinz Kaludzinski on
Chris Huff
    Top Expert:
  • LG Master
  • 6,289 Answers
Too many possibilities. Such as bad control board, low on freon, bad compressor, bad thermostat, etc. Best to call service technician.
Posted on Oct 26, 2018
5 Related Answers
Anonymous
SOURCE: flashing lights indesit wil103
you will need to unplug the machine at the mains, give it two minutes and the auto door lock will release your duvet, however start saving the pennies as your pcb is knackered and you'll be looking at about £200 to fix it
Posted on Oct 25, 2007
Anonymous
SOURCE: Samsung twin cooling fridge/freezer model
My husband removed the covers inside the fridge which contain the lights and the cooling fan. The problem was the icing up of the cooling fan (which circulates the cold air) preventing it from rotating also the drain hole at the bottom of the fan was also iced up.
The fridge was switched off at the wall socket whilst working on it. After removing the panel containing the fan and unplugging the connection take the panel outside. A hair dryer was used to thaw out the ice. The drain hole was made slightly bigger to hopefully prevent this happening again.
When panel is screwed back in fridge make sure the black sealing tape is in position also take care not to damage cooling pipes which are attached to the evaporator unit. Defrosting a couple of times a year might prevent this happening again. It seems to be a design problem which im sure the makers will be aware of and modify future appliances. Q Will the makers repair this problem free of charge even if the warranty has expired !?
Posted on Aug 01, 2008
Anonymous
  • 74 Answers
SOURCE: GE Profile Artica
The main PCB at the back of the appliance has failed
Posted on Aug 28, 2008
Anonymous
  • 448 Answers
SOURCE: LG LRBN20514ST Bottom Freezer Frig cooling problems
Unblockin vents....great....but is the fan blowing. It blows air from the freezer to the fridge in accordance to fridge temp you set. If you find this helpful, please post as such or go live chat for faster answers. TY
Posted on Jan 13, 2009
shaun greyvensteyn
  • 159 Answers
SOURCE: Fridge side of American Fridge/ freezer not cooling down.
does the fridge have 2 motors or 1 if it have only 1 motor the gas level in the system are low. if it have 2 motors check if the fridge side motor runs
Posted on May 22, 2009
Hi my lg inverter v is blinking lights when I switched on and not heating. when inspected out side, found the unit was buried in snow. so, I tried to switch on after clearing all snow and the fan too...
PDF]DEFINING COMMON ERROR CODES
www.lg-dfs.com/.../DFS-TP-AG-001-US_012H29_LGTechPaper_Error...
Aug 29, 2012 - Art Cool™ Mirror High-Efficiency Single Zone Systems ... Refer to Service Manuals posted on www.lg-dfs.com to troubleshoot ... Location of light-emitting... No. of Times Indoor Unit LEDs Blink ... Inverter compressor DC voltage is too high.... unit inverter compressor PCB heat sink temperature is too high.
[PDF]"Universal" Split Systems - LG Comfort Cooling
Jan 23, 2016 | LG Heating & Cooling
My LG model LMX 21984 circulating fan is not working, fridge cabinet is full of moisture. Please advise.
First you will need to find out why the fan is not working=> 4681JB1027C Evaporator Fan Motor Someone needs to test the voltage going to the plug where the fan plugs into the refrigerator wiring. Appliance 911 Sea Breeze Link to parts and fan location=> http://c.searspartsdirect.com/lis_png/PLDM/F1009005-00001.png
Dec 06, 2015 | LG Refrigerators
Hi there I have a LG esnw126 inverter,when I set it on cooling it doesn't run at all.the cooling indicate light is flashing 6times and flashing 2 times on the heating indicating light...help please
Our AC has had a lot of trouble over this summer and we recently had an issue just like yours. We ended up calling an air conditioning repair technician and had it resolved. It was the best thing that we did this summer because it is really hot right now but inside it is great! Ontario CA Air Conditioning repair Penny Plumbing
Aug 24, 2015 | LG Heating & Cooling
LG fridge is not working. NOT COLD in FREEZER or REFRIDGERATOR LED in main circuit board keep flashing
Look for a reset button, and try resetting . If compressor , is working and still not cooling , check refrigerant gas.
Oct 17, 2013 | Refrigerators
LG gn253sqa electro cool- temp. control lights in fridge keep flashing and fridge not cooling so good, help?
This has happened to me a couple of times.The problem is that when the fridge door is opened too may times the warm air of summer will block the cold outlets in the fridge with ice.The cold air comes direct from the freezer and the chamber connecting to the fridge clogs up with ice.What one has to do is completely empty the fridge and freezer,leave open both doors so the the ice build-up can melt.Then after about at least 4-5 hours (very important to stick by this time-frame as I tried a less time,but it did not work.),close both the freezer and fridge doors and switch it on.After about 1/2 hour replace your goods in the fridge.The down-side of this is that you will need the kindness of a neighbor or two to use their fridge to store your food whilst this fix is underway..
Feb 28, 2013 | GE (PSS26MSRSS) Side by Side Refrigerator
MY LG fridge model GR- M562 YLY
If you pull frig out from the wall, so that you can get behind it you will see a diagram with information on it. It states what happens with what test.
TEST1-All display lights come on
TEST2-Number 22 22 appears
TEST3-Number 33 33 appears
I have a question is your frig making a loud humming sound or a screach. If so it means that the fans need replacing.
Jul 21, 2009 | LG LRTBC1825T Top Freezer Refrigerator
May 17, 2009 | Samsung Refrigerators
Set the temp to low not high and wait 24 hours to see if the temp has drop.Also make sure the freezer is not icing up anywhere.If it is please repost.
Jan 13, 2009 | LG LRBN20510WW Bottom Freezer Refrigerator
Refrigerators Logo
157 people viewed this question
Top LG Refrigerators Experts
Colin Stickland
Colin Stickland
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
