Question about American Standard Plumbing
American Standard spray holder is loose (moves up & down). Sprayer does not retract or come out all the way. How do I repair?
Posted by Joan Smith on
5 Related Answers
Anonymous
  • 25 Answers
SOURCE: Water leaking down sprayer hose under sink.
They didn't put the attachment on correctly. Look at the directions for the sprayer. It's a black little piece with grey clips. U need to put it on correctly so it seals. That should stop the leak!
Posted on Jan 04, 2010
rickb63
  • 170 Answers
SOURCE: want to know how to fix sprayer on kitchen faucet
you can buy a replacement at a homecenter or hardware store for under $15
Posted on Jan 17, 2010
andrew wright
  • 56 Answers
SOURCE: the water does not spray inside, it does fill but
check your rubber seals to sprayer from back wall of dish washer. if ripped or dried out need to replace them.
Posted on Jan 24, 2010
Anonymous
  • 102 Answers
SOURCE: When I tgurn on the hot water on our American Stan...
Without seeing it I have to go by your descrption and my first guess would be the diverter. I would replace it and see if that does the trick.
Posted on May 22, 2010
Anonymous
  • 119 Answers
SOURCE: when turning on my American
Replacing the spray diverter or faucet cartridge ( depending on your model) will fix the problem. Call American Standard and ask for free replacement parts.
Posted on Sep 09, 2010
I have a B&K kitchen faucet (LM#203120) in my 2005 Newmar motor home. The spray wand has recently broken. The spray wand is approximately 6.5 inchs long and is connected to the water line by means...
If you are talking about the standard spray nozzel with trigger type control than replacement sprayers are reaidily available. You should be able to unscrew flex hose from nozzel at the base of nozzel where sprayer goes into holder on sink.There should be ribbed section on sprayer where flex hose goes in. Grip that section and turn upper section of sprayer counterclockwise to remove. Most hardware stores will have replacement nozzels for under ten dollars. Hope this helps. Thanks
Nov 12, 2010 | B&K Plumbing
When turning on my American Standard single faucet I get a water hammer noise and my sprayer also jumps?
Sep 09, 2010 | American Standard Plumbing
How do you fix the sprayer part doesn't flow without some spray, and sprays only partcal
hard water buildup will narrow the holes in the sprayer. What I did was got a round toothpick and poked it into each hole breaking away the calcium buildup . Try that and see
Jun 14, 2010 | American Standard Kitchen Faucet 6310 020...
Water leaking down sprayer hose under sink. American Standard Jasmine high flow 3821.831 or 834.
Jan 04, 2010 | American Standard Plumbing
Grohe sprayer faucet will not retract, spring around hose below.
check out the spring on the hose under the sink, sometimes they come loose on one end and they lose their spring back into the faucet
Jun 19, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
The pull out faucet is loose, wobbly, won't stay attached.
Make sure that there is a weighted ball connected about halfway down the retracting hose. If not you need to go to a supply house and purchase one and its a simple install.However if there is one attached you can loosen the 2 screws and slide it up closer to faucett but not so far that you can't pull out the sprayer as far as you need. Also make sure nothing is obstructing it under the sink. bottles, cleaners, etc.
Jun 04, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Kitchen faucet leaking pull down sprayer spout type
try tightening the nut that attaches the flex line to the pull out spout
May 04, 2009 | Price Pfister J103-BC 100 Series Kitchen...
Apparent flow blockage
I would turn off the water then check to make sure you have good flow up to the faucet itself. If you do then there might be a proplem with the cartridge or diverter. does it have a sprayer? If it has a sprayer head for the spout of the faucet then there will be what the call a check valve inside the spray head itself that canbe removed with a skinny screwdriver or something thin and long
Apr 29, 2009 | American Standard Kitchen Faucet 6310 020...
Plumbing Logo
221 people viewed this question
Top American Standard Plumbing Experts
Bill Johnson
john h
Fahr Quad
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
