Garmin StreetPilot c340 GPS Receiver Logo
Question about Garmin StreetPilot c340 GPS Receiver
Garmin c340 takes approx. 15 blocks before speed registers. Why and what can be done to fix this?
Posted by Brian McLaren on
4 Related Answers
Ron Chinnery
  • 52 Answers
SOURCE: garmin c340
First, be sure you are outside, in the open when making this diagnosis. Some cars have metallic defrosting layers, which blocks the GPS signal. If, when outside in clear view, you still have problems, try this...
Have you tried a hardware RESET? The button is hidden behind the front panel, which snaps off by a fingernail slot located directly under the GARMIN logo on the front panel.
* Use caution removing and reinstalling the front panel... it's somewhat fragile... wiggle it a little to get it off.
Press where it says "Press to Reset", hold for a second or two. Charge the unit with the car cord or USB cable, then try to turn it on again.
Once you can get the unit to (hopefully) turn ON, you should run all updates (there may be several!) using Garmin's Webupdater. (Connect to computer with USB cable first.)
Hope this helps!!
Posted on Jul 18, 2008
Anonymous
  • 5 Answers
SOURCE: speedometer appears to register 15 miles less than actual speed
If you have replaced your stock size tires with oversize aftermarket tires and wheels (17 inch stock wheels to 22 inch wheels, etc) you need to have the computer reflashed to compensate for the larger tire size. Larger tires turn slower to maintain the same groundspeed, giving a false speed reading.
Posted on Apr 10, 2009
Anonymous
SOURCE: update 2009 maps into c340 how to
The Garmin Streetpilot C340 is discontinued, so there isn't much support for it. You can find some updates at
https://buy.garmin.com/shop/store/downloadsUpdates.jsp?product=010-00401-20&cID=164&pID=290
But no free map updates.
Posted on May 13, 2009
Anonymous
SOURCE: Garmin C340 will not take a charge.
The internal battery needs replacement. You can change it yourself if you are comfortable with soldering, and are mechanically inclined.
Search the internet for:
"Replace battery Garmin c330" You'll need a small Philips head screwdriver to open the case, and to remove the battery holder. It is tricky to put the antenna back, so be careful.
Posted on Jul 20, 2009
I used the Garmin Web Updater download to update software on my Garmin StreetPilot C340 GPS and it now indicates that I am in Olathe KS...I am in ND. How do I fix that?
Have you been outside with the unit since the update? Usually when you take the unit outside and turn it on, it reads the satellites and gets it's location from those.
How do I update my Garmin c340?
register at garmin.com. You then need to plug it into you PC and Garmin will allow you to update the internal software and will sell you the latest maps,
2helpful
Map updates for garmin340 free?
When you first connect to the Garmin web site you will be asked to register you GPS. After you register you will be able to download the latest maps for free (One Time).
Garmin street pilot c330
You have to pry off the silver-colored faceplate from the unit and you will find a reset button on the right side of the screen. Push this and everything will back to normal.
2answers
Error when downloading map updates
Try using a different website where you can download the maps for free. These should work. If they don't, you might need a software update from the same web site before getting more maps: www8.garmin.com/support/collection.jsp?product=010-00401-20
1helpful
2answers
My Garmin C340 is dead!!!!
I had the same problem on a trip. Required two fixes and once I did this the unit worked fine.
1. Replace the fuse in the car adapter (reason it wasn't charging when I used it in the car).
2. See the users manual on page 31 regarding resetting your C340.
http://www8.garmin.com/manuals/StreetPilotc340_OwnersManual.pdf
Garmin c340
Resetting it and recharging it again wsemed to work for me
Tech Help
You need to calibrate the touch screen. With the unit off press and hold the power button until the calibration screen appears (approx 35 seconds). The follow the instruction on touching the dot on the screen. Once this is done your screen should be OK.
1helpful
5answers
C340 user manual
my garmin 340 use to mention the street name, now it just tell me to "make a left" " or " a right" without naming the street as it used to do. How do I get it back to mentioning the street direction.? Thank youy
1helpful
3answers
Garmin c340 gps freezes up
Avoid buying Garmin GPS. Their units have a non user replaceable battery that last about 2 years. After that, you have to send the unit to Garmin to replace the battery and be hit with at least $150 plus shipping. Possibly more if they need to fine tune something else. Look at other brands with easier battery replacement such as Sony, Navigon, etc. Garmin is a total rip off.
Top Garmin GPS Experts
Marvin
Marvin
Steve
Tom Chichester
Are you a Garmin GPS Expert? Answer questions, earn points and help others
