SOURCE: Hoover washer Time 1600 H160E UK stops mid cycle with flashing lights
REPLACE TIMER OR POWER CONTROL BOARD
SOURCE: washer won't run through a complete cycle-stops at 29 minutes
There is a service manual behind the control panel it will show you how to test the door locks. If might have a bad lock solenoid.
SOURCE: my door will not shut and there is no tension on
make sure the strike is adjusted correctly.. it may have gotten bent out of place.. the strike is the little metal tab that comes off of the top of the center of the tub and goes into the door when you close the door.
SOURCE: washer says DC and stops on rinse cycle
DC= Distribute Clothes: The load is unbalanced, preventing high speed spin. Redistribute clothes.
SOURCE: My washer stops during cycles
You must be using too much detergent or the wrong stuff. Most of these machine sense the motor amp draw. If oversudsing occurs the washer will work harder to try and remedy it. Making it get hot and quit. It will try to do some routines to get rid of suds in the tub. You have to clean out the dispenser and use the correct amount of the correct stuff.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
