Having replaced the heating element the dryer now heats up but the sensing function is not working i.e the dryer just stays on full heat instead of cooling once the clothes are dry. Is this likely to be one of the thermostats or another issue like the pcb? Thanks Peter
SOURCE: Dryer Heats - Drum Turns - Clothes Don't Dry - Dryer Seems To Over Heat
Before ripping into the dryer, with the dryer running, check the vent outside. There should be a rather strong air flow. I'll bet you have little or maybe no air flow. Check behind the dryer to make sure you don't have squished flex duct. If you have flex pipe, try running the dryer for a few minutes with the dryer pulled out into the room to stretch the vent out, and check outside airflow again. Try to eliminate all or as much of the flex stuff as you can, replacing it with aluminum dryer vent pipe. (tape joints with foil duct tape) Clean out remaining dryer vent. (there are special brushes you can buy to clean out vents, but they really only work on ridgid pipe.)
SOURCE: no heat in tumble dryer
Is this a gas dryer, if so check the thermal fuse, should be white plastic with 2 wire ports. These tend to bad first. Thanks Dave www.washermd.com
SOURCE: Dryer not heating, still tumbling
your heating element could be burned out...or a thermal switch could be stucknot allowing the element to turn on
SOURCE: white knight tumble dryer not drying clothes.
How to Replace A
White Knight Tumble Dryer Heating Element Heater and Thermostat
For a full list of appliance
Video Repair help see our video section
White knight tumble dryer not heating this video show you
how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux,
Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into
our search bar at http://www.apart4u.co.uk/ TEL 08455218000
http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
Problem solved following a callback from manufacturer technician. It turned out that the carbon brush had become dislodged from its holder on top of the drum! With brush in place machine performs correctly.
