Televison & Video Logo
Question about Alba Televison & Video
Hi I have an Alba tv that needs a Chanel update or scan thing, but I don't have a tv remote, and I cannot use the buttons on the screen to make it happen,i can get the menu up but I can't seem to find an okay button to sort it. (Sorry for bad pic)
2helpful
I have an alba 24”tv and just set up. All fine except when I select guide on tv and select channel pressing ok. I have the sound but no picture it stays on guide screen. If I press source and free view I...
This is a common trait with cheap brands. Alba are a cheap brand for a reason. Supermarket own brands also suffer flaws like this.
Cheaper usually means you lose a lot of functions that make life easier. Take Polaroid a cheap brand for Asda supermarkets. Use one of there TVs and you’ll see the same thing. You can press guide. You don’t get a tv picture in the guide like most more expensive brands. Select a channel. Press ok. Normally your guide would close once you press ok. But on these TVs you have to press ok. Then yet again press guide to close the TV guide to watch the channel.
When you buy cheap the normal practice is you give up silly things and quality that make normal life easier on proper brands like Sony or Samsung.
Some cheaper TVs you’ll also find don’t have a network or Ethernet connection or WiFi. To enable use of software updates. Cheaper TVs normally have to rely on “over the air” updates meaning the update has to be broadcast over UHF the same way your tv channels are. This is very rarely done as the updates can be to large in size.
It’s simply just the design of the tv you have. Cheaper doesn’t always mean better.
Alba portable tv/dvd combi
Main board fault. Contact any service technician.
I have Sony TV analog, I used Zenith Coverter Box now. Yesterday, I entered the MENU, Scan All, Scan update, then go lower, chanel 3, 4 ..... and suddenly my TV NO signal, just see lines on screen of TV. I...
Converter box issue - look for a reset to factory defaults .If that does not take care of the issue you will need a new converter. Fortunately they are not expensive.
1helpful
I have a Sony tv that the Chanel display stays on the screen. I don't have the orig remote. Any thoughts on that. Thanks.
No universal will work for this, almost any Sony TV remote will with the DISPLAY BUTTON remove that--not too hard to understand, you have to have a Sony remote for any of their TV sets made in last 20 years that has the "display" to get this off the screen.
1helpful
Sanyo model # ds19310 16 jnch tv stuck on video chanel wont change to any other chanel volume works pat of menue works but the channel search and two other chanel menue controls are not available tv skips...
If you still have the Sanyo remote, you just need to press the INPUT button on the remote. The channel search and some other functions are disabled when the TV is in video/AV/game mode.
If you don't have the Sanyo remote, but you have a Universal remote which you use with the TV, look for a button labelled INPUT or SOURCE on this remote and try pressing it.
If you don't have any remote for this TV or you are using a universal remote which does not have an INPUT or SOURCE button, please reply to me from within this page for further assistance and let me know the brand and model number of any universal remote you are using. There is no option in the menu for doing this, but there a couple of methods which work on some TVs
Hope this helps.
Regards,
BElectric
3answers
I need a user manual for a Techwood LVD2263D flatscreen tv. I cannot install & re-tune to view TV channels
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers, for spare parts and service and Installation Instructions as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
48helpful
4answers
Alba tv remote has stopped working
hi had the same problem with alba 42" (l42m1) spoke to customer services at argos who suggested holding down menu button for 10 seconds then pressing menu again, which aparantly resets remote with tv. Has worked for me, hope it works for you.
How do i get the chanel diplay off when watching tv
Press Display/ Info button on TV remote, on-screen display will disappear.
TV original remote will work.
Thanks.
1helpful
I NEED THE CODE FOR ALBA TV MODEL NO. ALCD15TV8M
There are two code types for sky remotes, Brand Codes & Direct Codes.
The codes for Alba are:
Brand - 0043
Direct - 037, 065, 246, 399, 263, 064, 446
There is a small difference in the way they are set.
To program using the 3 digit code - Direct Code
1) Switch on the TV set
2) Press the TV button on the Sky Remote
3) Hold down the select and red buttons for 2-3 seconds until the LED blinks twice
4) Enter the 3 digit code
5) Press the select button to store
Press TV and any number to test, If this does not operate the TV set try below.
To program using the 4 digit code - Brand Code
4) Press the TV button on the Sky Remote again
5) Enter the 4 digit code for your make of TV
6) The LED should blink twice, if not recheck the 4 digit code used and go back to 1
7) Press the standby button on the Sky Remote (The TV should go to standby)
8) Press select to store this setting
If the TV does not go into standby press the TV button then the standby button, then TV then standby, keep repeating this until successful. This will scan the codes used for a particular make of TV.
Top Alba Televison & Video Experts
 Grubhead
Grubhead
NOEL
NOEL
Are you an Alba Televison and Video Expert? Answer questions, earn points and help others
