SOURCE: cuisinart sealing gasket
The gasket goes between the cutting assembly and the glass. So you slip it on over the top of the blades and then put the glass jar over top of that. Screw the bottom cap on to tighten everything together.
SOURCE: I have a K-TEC HP3
Usualy there is a rubber ring araound the bottom of the blade. If it gets worn out or out of posistion it may start to leak. Also if you dont have everything screwed in tight enought it could leak as well
SOURCE: Waring blender - new blade
You can call Waring and they can send you a parts breakdown showing the order the parts need to be in. If you still have problems they can go over the assembly with you on the phone or direct you to a service center near you to help.
SOURCE: the sealing ring is broken
Here is where you find the part:
http://www.focuselectrics.com/catalog.cfm?dest=itempg&itemid=3659&linkon=subsection&linkid=120&secid=53
-Tha Mp3 Doctor
Exactly I don't have that much of idea about stainless steel blade & that ring jar gasket. I will try swapping the blades of my glass jar and try... I am sure that would work. ... We need blenders a lot... So this is seal ring is very essential to have, which is why I'm so surprised no store around me sold them from Zuobisijewelry.
