Optics Logo
Mills Jack Posted on Jun 07, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Which is better for wildlife safari monocular or binocular?
Adam Howard
Level 2:
Habit-Forming:
  • Expert 63 Answers
  • Posted on Jun 07, 2018
Adam Howard
Expert
Level 2:
Habit-Forming:
Answers
63
Questions
48
Helped
13870
Points
325
In your choice of Which is better for wildlife safari, you will have to consider what you are actually looking out for first. Do you want some thing light and portable at the expense of some extra comfort and convenience? Or you would rather be as relaxed as possible and get all the glimpse in style but bear the burden that comes with this. Monocular are Sometimes perceived as inferior to binoculars for wildlife viewing because of the flatter image derived from a single objective lens. But monocular have the advantage of being easier to carry and lighter in weight than binoculars. A monocular can fit in your pocket or be carried on a strap around your neck or looped on your belt. Although Observing with both eyes open is certainly more comfortable and relaxing than just with one.
1helpful
What is a Monocular?
A monocular is a miniature, low powered telescope or spotting scope which you hold in your hand like a binocular but use with one eye like a telescope. A monocular shares characteristics with both binoculars and spotting scopes, but is much smaller than either. Size, then, is really what a monocular is all about. Some monoculars are no larger than your thumb or thicker than a good ink pen and any monocular will slip easily into a pocket or a purse. When a Spotting Scope or a Binocular, even a compact, is too large to take along, there is always a monocular. There is no excuse for leaving home without the monocular.
Apr 04, 2018 • Optics
1helpful
How do I select a monocular lens?
Having a monocular is a great alternative other than carrying a pair of binoculars. They are significantly more compact, lightweight and portable but they come with only the half of the size of binoculars. The following article talks about how to Select the best monocular lens between your budget and needs.
Need to consider the points below:
  • Monocular vs. Spotting Scope
    A monocular significantly featured a compact and portable design. Monocular lenses that are bigger generally have more power, larger lenses and wider views are known as spotting scopes. A spotting scope will be notably greater and heavier than a typical monocular which are frequently used for bird watching, hunting, or spotting subjects from a static position. In case require better performance, and you are compatible with the size or weight, then you have the hardly better option than a spotting scope
  • Good Monocular Power
    The power or magnification are the things that you should consider first when choosing a monocular lens. This device typically has a higher magnification of 6x to 10x which will allow you to see further and in more detail. The monocular with 9x or 10x magnification will usually slightly high priced more than 6x or 8x ones. The good thing is, about this device, that you can get the same power of binoculars, but they are only half of the size of their counterpart.
  • Right Lens Size
    If you look at the specifications of a monocular, you will find two numbers. For instance, 8×25; which means 8x, the first number, denotes its power, and 25mm, the second number, represents the size of its lens.
    A monocular comprises with a lens of 20mm to 42mm. With a bigger monocular lens, you can observe see a wider view, and will also result in a better, sharper image while looking through the device. The downside is that the larger the size of the lens is, the heavier and bigger the device will be.
  • Monocular Size and Weight
    On the whole, an 8×25 or 10×25 monocular is considered to be a pocket-size or compact device which will simply be fit in your pocket. They usually come with a small carrying bag. The pocket monocular works as a cool device. They are very portable as it is easy to carry them around everywhere - keeping in the car or in the pocket when climbing. These devices are low-priced and can also serve well.
    You will have to keep it in your mind that an 8×25 or 10×25 pocket monocular is very small, so you cannot expect too much performance from it! These tiny monocular have a small lens but can provide a very limited view though they have good power. At first, you will need to detect your subject and later use the monocular in a "point and shoot" style. It is not at all easy to use them since they have a small eyecup. If you want to enjoy a wider, sharper and brighter image, then you should always opt for a 30mm to 42mm monocular.
  • Night Vision Monocular
    If you are planning on buying a monocular in order to use at night or whole darkness, then you should go for a night vision monocular. IR illuminator is built-in these devices which will increase your night vision capability. Having less magnification, you can use them normally to get a better image and off course less fuzzy. These monocular usually come in different sizes, magnification and price range.
This guide helps you to choose a monocular lens that you are looking for.
Mar 19, 2018 • Optics
My binoculars are very dirty and gritty from safari drives. How or where can I get the cleaned and usable again
Joan, try a camera repair shop, they deal with this type of cleaning all the time.
Press the helpful button and Follow me on Fixya for more tips
Jan 27, 2016 • Optics
1helpful
How do i tighten the swing action on my stiener safari binoculars?
These binoculars have a 10 yr warranty, so you may contact steiner (http://www.steiner-binoculars.com/) for repair for a nominal charge, however there is an easy fix: You'll need a small (about 1/4 in) screw driver.
1. remove the objective lens protector. This is the small metal piece on the binocular side that is loose, opposite from the eyepiece(part you look through). It appears impossible to "pop" loose from the outside, but if you slip your finger inside(try not to smudge the lense), you'll feel a significant ridge. You may be able to pull / pop it off with your finger, or a small handle.
2. Tighten the screw that is now exposed. Do not overtighten, just a little tighter than what it takes to keep it from "falling" on its own weight.
3. Pop the lens protector back on the object lens.
1helpful
I received new binoculars for Christmas Infinity elite ELX 10 x 42. There was no manual or information in the box. Do I need to call the store where they were purchased or can I download a manual?
I don't think they have instructions! Just adjust the eye cups and the focus dial on the top. Here's some info I found for you.
General Specifications:
magnification factor
10
objective size
42 mm
exit pupil
4.2mm
eye relief
15.0mm
close focus
2.0m, 6.6'
angular field of view
6.3°
linear field of view
330 feet at 1000 yards
relative brightness index (RBI)
not specified
coating
silver and phase coated
prism type
BaK-4
tripod adapted
no
twilight factor
not specified
weather protection
waterproof, fogproof, submersible to 1.5m for 3 minutes
classification
bird/nature, hiking/camping, hunting/wildlife
Physical Specifications
weight
706 g
dimensions
not specified
color
black
Additional Information
warranty
No fault lifetime Promaster warranty, Warranty information may change. Warranty information can also differ by region.
included accessories/ features
carrying strap, deluxe case
2answers
My Swarovski Binoculars do not focus...everything is blury. These are the BEST Binoculars I have ever had...I can't live without them. I am a Wildlife Photographer. How can I get them repaired ASAP....
Your Swarovskis should be under warranty and need to be repaired by Swarovski. If its not under warranty they still should go to Swarovski. Unfortunately not a quick fix but the only way to go with optics of this calibre.
Jul 04, 2009 • Optics
Need replacement parts to steiner safari 8x22 eyecups
www.steinerpartsdirect.com
They are Steiner authorised. Binoculars.com used to list many Steiner parts as well.
1helpful
Pictures bad when uploading
this is a cheap knockoff of a camera, the maximum quality is 640x480 I can find these for 20 dollars. Its just bad quality there noting you can do about it. you have to buy a better camera, or a better binocular camera.
Top Optics Experts
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you an Optic Expert? Answer questions, earn points and help others
