Question about Golf
What is the best way to wash golf gloves? - Golf
Posted by Mills Jack on
Adam Howard
    Habit-Forming:
  • 59 Answers
I wouldn't recommend washing a golf glove. This could damage the leather material, thus making the glove stiff when it dries. Just leave it to air dry after you play your round, that should prevent any unpleasant odors. I always carry more than one with me when I play.
There are some good golf gloves list : Best Golf Gloves
What is the best way to wash golf gloves? - xspann-whiteredblack-2-hfson1e1m1n1opgvgdwiz4el-3-3.jpg
Posted on Jun 06, 2018
How long should golf gloves last?
That depends on how much you golf and how strong you hold the golf club. If you golf about twice a week and you don't grip the club that hard, the grip on the gloves will probably wear out in 4-5 weeks.
Jun 05, 2018 | Golf
Tip
Tips on Choosing best sunglasses for golf
Polarization - The most important factor in choosing the best golf sunglasses for you should be how much of the suns harmful UV rays they block. Ideally the best golf sunglasses will block out 100% of the UV rays without limiting your vision.<br />Most manufactures will rate how much UV rays they block with a nanometer chart. The higher the nanometer rating the better.Weight- The second most crucial factor in choosing the best golf sunglasses is the weight. Having a bulky pair of golf sunglasses can shift too much or even fall off when swinging a club, completely distracting your focus. These days there is an abundance of golf sunglasses made out of technologically advanced lightweight materials. The best golf sunglasses should be so light you barely notice them on your face.Style- This factor may be at the top of the list for some in choosing the best golf sunglasses for them. After all, impressing the drink cart girls with your sense of style is pretty important. Some guys can pull off just about any look, but when shopping for the best golf sunglasses you should try a lot of different models on to make sure you don't choose a style that doesn't work for you. In finding the best golf sunglasses you will want to find which frame type and lens shape fits your face the best.<br /> Price - Although some golfers spend enough money to feed a small village on golf gear, obtaining the best golf sunglasses for you doesn't have to break the bank. Surprisingly, some of the best golf sunglasses we've come across are some of the most economically priced.<br /> Where to buy- Typically golfing sunglasses can be overpriced at country club supply shops.
on Nov 07, 2010 | Clothing Accessories
Find the year serial nimber A9649-548612 club car golf cart was manufactured
Since 1981 Club Car Golf Carts have positioned their serial numbers just under the glove box on the passengers side of the vehicle. The first two numbers (not letters) indicate the last two digits of the year of manufacture.
On Club Car Golf Carts prior to 1981, you can find the serial number by raising the seat and locating the aluminum, I-beam frame section closest to the batteries on the driver's side of the car. If the serial number plate has been removed, you can confirm it is a 1975-1980 model if it has two brake pedals and one accelerator pedal.
Oct 20, 2014 | Golf
Is it ok to use my batting gloves for golf?
I used my baseball batting gloves for golf and had no problem. It helps me grip just the same as authentic golfing gloves do.
Feb 06, 2013 | Baseball & Softball
What is a golf glove?
Golf gloves help to grip the club and prevent blistering. Gloves are sold individually and normally worn only on the players' non-dominant hand, but it is not unheard-of for a player to wear gloves on both hands to reduce chafing.
Feb 06, 2013 | Clothing Accessories
The catch on the glove box lid on a vw golf 2001 is broken how do i fix it?
You need to replace the whole glove box door. Pry the panel on the right side of the dash off, remove the t25 screw, remove the 3 t20 screws along the bottom of the glove box, and the t20 screws that you can see inside the glove box. This will loosen it enough to pull the whole glove box loose. Then you need to remove the damper by prying the little plastic pin out. Then remove the bracket it secures to that has a t20 screw in it. There are 2 plastic pins in the hinges that need to be popped out, once this is done, the door will come off. Reassembly is the reverse.
If the pins are difficult to reinstall, file the new glove box door hinge holes with a round file. I usually shoot a little oil into the damper too, just to make operation easier.
Feb 04, 2011 | 2001 Volkswagen Golf
2006 VW Golf 2.0S SDI - where is cabin filter located & how do I replace?
most cabin filters are under passenger side dash/glove box, but all are different to get to sorry I'm not sure how vw has theirs
Aug 29, 2009 | 2006 Volkswagen Golf
Glove box lid golf mk4 2002
take it to any autozone. they will show u how to take it off and loan you tools to do it.
Apr 22, 2009 | 2002 Volkswagen Golf
Replace fuses in a 2004 VW Golf
I had a '93 Golf until recently and the fuse layouts were shown in the User Manual - the booklet in the glove compartment. Hope this helps, D.
Aug 13, 2008 | 2004 Volkswagen Golf
Golf Logo
241 people viewed this question
Top Golf Experts
FastHarley
FastHarley
ray gallant
Kardoc
Are you a Golf Expert? Answer questions, earn points and help others
