Question about Yamaha Ef600 Generator/inverter Repair/service Manual
My ef600 started and ran to full rpm for about 10 to 15 seconds then then back to idle speed, now only runs at idle speed
5 Related Answers
Anonymous
  • 13 Answers
SOURCE: idle problem
you can't adjust the idle it's all done by the pcm.you might have a IAC going bad or sticking(idle air control solenoid)
Posted on Jun 25, 2008
Anonymous
  • 21 Answers
SOURCE: clicking sound,low rpm idle, and
If you ever have an oil leak it really should be fixed right away unless this happened all at once. Go to a local mech or if there is an Autozone around go there and have them check the Engine Light code for you for free. You will have more info to work with.
Posted on Jul 31, 2008
Anonymous
  • 15 Answers
SOURCE: High Idle speed on 1989 Merc Sable, 3.0L V-6. Approx 2000 RPM
My wife had a 93 ford tempo 4 cylinder with same problem.It turned out to be the idle air solenoid mounted on the air intake manifold.
Posted on Jan 17, 2009
Anonymous
  • 6 Answers
SOURCE: 1989 Bronco starts but dies after a couple of seconds
try checking the thermostat control senser. it caused my bronco to start for a second and then die. after a while it would finally start and run for a while then die driving down the road. i changed the thermostat control senser and it fixed all problems of dieing
Posted on May 10, 2009
tombones
  • 3567 Answers
SOURCE: 2005 Katana....Idle (warm) slowly goes from 1,100 to 2,000 rpm
There is an air leak letting outside air into the fuel/air mix. This leans the mix and causes the problem you describe. The diagram below shows the likely carb air leak areas; "O" ring seal dried out, clamp seal bad due to loose clamp or hardened manifold rubber, rubber manifold dried out / cracked, the vacuum cap is loose. Other sources are a loose spark plug, bad valves and leaking head gasket.
Can I get a “very helpful” rating on this answer?
Posted on Aug 29, 2009
Testimonial: "Thank you very much. I called the local Suzuki dealer (who just installed an APE Manual Chain Tensioner) and they said it sounded like a vacuum leak. "
Ryobi 725r trimmer carburetor adjustment
Turn both low and high adjustment screws carefully clockwise all the way in - do not overtighten.. Then back out each two full turns. Set the idle speed control for highest setting. Prime and start and let it run and warm up for about 15 seconds - then lower the rpms a tad and then adjust the low end screw for highest rpm. Then reset the idle to lower reasonable level. You may have to go back and forth with those two adjustments till it runs fine at low idle speed..
Then accelerate to highest speed and set the high adjustment for highest rpm. Then go from idle to high speed. If not smooth a small adjustment on the high speed screw is in order. Keep doing that until you get a nice smooth transition form low speed to high speed.
Mar 11, 2017 | Ryobi Garden
2000 Honda shadow vt750 running rich and can't get a smooth idiol
Hi, Ej the carburetor throttle shaft wheel has two cables the cable closest to the right side of the bike is the throttle cable and the one closest to the left side is the idle cable. Right about the middle between the two is the idle adjustment bolt it faces out towards the air filter end of the carb. The engine should be at operating temperature with the enrichener off to set the idle between 950-1050 rpm. Turn the idle adjustment bolt clockwise to increases idle speed and counterclockwise to decrease idle speed. If you have access to your air fuel mixture bolt you may adjust it as well if not there is a video below on how to gain access, make sure you start with clean or new spark plugs. Gently turn the air fuel mixture bolt clockwise until it starts to bottom out "STOP" do not over tighten as it will damage the taper on the end, now back it out 2 full turns to establish a starting point start the engine and check the idle rpm's and adjust the idle adjustment bolt accordingly for 950-1050 rpm if necessary, adjust the air fuel mixture bolt 1/4 turn at a time and let the engine settle for about 10 seconds, clockwise for a leaner mixture and counterclockwise for a richer mixture you are seeking the highest rpm your air fuel mixture bolt can acquire without going past 3 full turns from bottom then readjusting the idle adjustment bolt back down to 950-1050 rpm If you can not detect any rpm change and can not stall the engine by turning the air-fuel mixture bolt all the way in then your pilot/low-speed jet is too big. Final adjustment should be made with a clean air filter mounted to the carburetor. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Adjusting the Mixture Screws
Running Rich
http://www.vt750dc.com/HONDA_VT750DC.pdf
http://www.partsfish.com/page/oem-parts-for-honda
http://www.vt750dc.com/VT750DC_OwnersManual.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Dec 25, 2016 | 2000 Honda VT 750 C2 Shadow
Ryobi 725r carb adjustments
Zama Carb? Turn both low and high meter screws 2 full turns counterclockwise, and idle speed control to maximum. Prime unit and start motor. Run for about ten seconds and then turn idle jet (clockwise) for maximum rpm and then lower idle rpms - readjust idle meter as necessary along with idle screw. Then gun unit at high speed and turn high screw for maximum rpm. Go from idle to max and make sure there is a smooth transition. If not play a tad with the idle mixture screw till that is achieved.
Oct 22, 2015 | Ryobi Garden
The motorcycle starts but I can not keep it running
Hi, Anonymous it should be noted I am not allowed to use the word "SCR*W" as Fixya considers it profane. The carburetor throttle shaft wheel has two cables the cable closest to the right side of the bike is the throttle cable and the one closest to the left side is the idle cable. Right about the middle between the two is the idle adjustment bolt. It faces out towards the air filter end of the carb . The engine should be at operating temperature with the enrichener off to set the idle between 950-1050 rpm. Turn the bolt clockwise to increases idle speed and counterclockwise to decrease idle speed. If you have access to your air fuel mixture bolt you may adjust it as well if not there is a video below on how to gain access, make sure you start with clean or new spark plugs. Gently turn the bolt clockwise until it starts to bottom out "STOP" do not over tighten as it will damage the taper on the bolt, now back it out 2 full turns to establish a starting point start the engine and check the idle rpm's and adjust the idle bolt accordingly for 950-1050 rpm if necessary, adjust the A/F mixture bolt 1/4 turn at a time and let the engine settle for about 10 seconds, clockwise for a leaner mixture and counterclockwise for a richer mixture you are seeking the highest rpm your A/F bolt can acquire without going past 3 full turns from bottom then readjusting the idle bolt back down to 950-1050 rpm If you can not detect any rpm change and can not stall the engine by turning the A/F bolt all the way in then your pilot/low-speed jet is too big. Final adjustment should be made with a clean air filter mounted to the carburetor. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
2004 Vstar idle only on full choke problem
http://forums.cycleworld.com/showthread.php?t=169267
98 00 Yamaha XV650 Star Service Manual XVS650 Moto Data Project
OEM parts for Yamaha
http://www.starmotorcycles.com/assets/service/manuals/2003/LIT-11626-16-05_22.pdf
Jun 28, 2014 | Yamaha V Star Classic Motorcycles
2013 Honda Activa will not idle when warm
Hi, Anonymous you need to make sure you have no intake leaks by spraying some Brake Kleen, Contact Cleaner, Starting Fluid etc. around the intake manifold and seals, if the RPM's go up or down significantly then you have a leak that needs to be fixed before you can continue with the carburetor adjustment.
The engine should be at operating temperature with the enrichener off to set the idle between 950-1050 rpm. Turn the idle skrew clockwise to increase the idle speed and counterclockwise to decrease the idle speed. If you have access to your air fuel mixture skrew you may turn it as well, if not there is a video below on how to gain access, make sure you start with clean or new spark plugs. Gently turn the air fuel mixture skrew clockwise until it starts to bottom out "STOP" do not over tighten as it will damage the taper on the end, now back the skrew out 1-1/2 full turns to establish a starting point start the engine and check the idle rpm's and turn the idle skrew accordingly for 950-1050 rpm if necessary, turn the air fuel mixture skrew 1/4 turn at a time and let the engine settle for about 10 seconds, turn the skrew clockwise for a leaner mixture and counterclockwise for a richer mixture, you are seeking the highest rpm your air fuel mixture skrew can acquire without going past 3 full turns from bottom then resetting the idle skrew back down to 950-1050 rpm If you can not detect any rpm change and can not stall the engine by turning the air-fuel mixture skrew all the way in then your pilot/low-speed jet is too big and needs to be replaced with the next size smaller. Final adjustment should be made with a clean air filter mounted to the carburetor.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Honda Activa 2013 Engine Stalling
Honda Activa Engine idling stalling issue caused by faulty ring fitment...
http://www.family-motorsports.net/GY6-50cc-150cc.pdf
Honda activa 2009 Owner Manual
Jun 28, 2014 | 2011 Honda Activa
1989 Kawasaki Vulcan 750 will not idle
The engine should be at operating temperature with the enrichner off to set the idle between 950-1050 rpm. Turn the idle skrew clockwise to increase the idle speed and counterclockwise to decrease the idle speed. If you have access to your air-fuel mixture skrew you may turn it as well, if not there is a video below on how to gain access, make sure you start with clean or new spark plugs. Gently turn the air fuel mixture skrew clockwise until it starts to bottom out "STOP" do not over tighten as it will damage the taper on the end, now back the skrew out 1-1/2 full turns to establish a starting point start the engine and check the idle rpm's and turn the idle skrew accordingly for 950-1050 rpm if necessary, turn the air fuel mixture skrew 1/4 turn at a time and let the engine settle for about 10 seconds, turn the skrew clockwise for a leaner mixture and counterclockwise for a richer mixture, you are seeking the highest rpm your air fuel mixture skrew can acquire without going past 3 full turns from bottom then resetting the idle skrew back down to 950-1050 rpm If you can not detect any rpm change and can not stall the engine by turning the air-fuel mixture skrew all the way in then your pilot/low-speed jet is too big and needs to be replaced with the next size smaller. Final adjustment should be made with a clean air filter mounted to the carburetor.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
http://www.vn750.com/forum/22-carbs-fuel-system/50473-will-not-idle-without-choke.html
1986 Vulcan 750 not idling running Kawasaki Vulcan Forum Vulcan Forums
Kawasaki VN 750 Service Manual
OEM Parts for Kawasaki
1989 Kawasaki Vulcan 750 Owner Manual
Nov 06, 2013 | 1988 kawasaki VN 750 Vulcan
1979 Honda CBX will not idle
The engine should be at operating temperature with the choke off to set the idle between 950-1050 rpm. Turn the idle skrew clockwise to increase the idle speed and counterclockwise to decrease the idle speed. If you have access to your air-fuel mixture skrew you may turn it as well, if not there is a video below on how to gain access, make sure you start with clean or new spark plugs. Gently turn the air-fuel mixture skrew clockwise until it starts to bottom out "STOP" do not over tighten as it will damage the taper on the end, now back the skrew out 1-1/2 full turns to establish a starting point start the engine and check the idle rpm's and turn the idle skrew accordingly for 950-1050 rpm if necessary, turn the air-fuel mixture skrew 1/4 turn at a time and let the engine settle for about 10 seconds, turn the skrew clockwise for a leaner mixture and counterclockwise for a richer mixture, you are seeking the highest rpm your air-fuel mixture skrew can acquire without going past 3 full turns from bottom then resetting the idle skrew back down to 950-1050 rpm If you can not detect any rpm change and can not stall the engine by turning the air-fuel mixture skrew all the way in then your pilot/low-speed jet is too big and needs to be replaced with the next size smaller. Final adjustment should be made with a clean air filter mounted to the carburetor.
1979 Honda CBX Cold Start and Idle
Lazy Slow Return to Idle or Erratically High Idle
Honda 1979 CBX Shop Manual
1979 Honda CBX Owner Manual
Apr 19, 2013 | 1979 Honda CBX
2009 v star 1300 won't idle runs rough
Hi, Snakeman_982 the carburetor throttle shaft wheel has two cables the cable closest to the right side of the bike is the throttle cable and the one closest to the left side is the idle cable. Right about the middle between the two is the idle adjustment bolt it faces out towards the air filter end of the carb . The engine should be at operating temperature with the enrichener off to set the idle between 950-1050 rpm. Turn the idle adjustment bolt clockwise to increases idle speed and counterclockwise to decrease idle speed. If you have access to your air fuel mixture bolt you may adjust it as well if not there is a video below on how to gain access, make sure you start with clean or new spark plugs. Gently turn the air fuel mixture bolt clockwise until it starts to bottom out "STOP" do not over tighten as it will damage the taper on the end, now back it out 2 full turns to establish a starting point start the engine and check the idle rpm's and adjust the idle adjustment bolt accordingly for 950-1050 rpm if necessary, adjust the air fuel mixture bolt 1/4 turn at a time and let the engine settle for about 10 seconds, clockwise for a leaner mixture and counterclockwise for a richer mixture you are seeking the highest rpm your air fuel mixture bolt can acquire without going past 3 full turns from bottom then readjusting the idle adjustment bolt back down to 950-1050 rpm If you can not detect any rpm change and can not stall the engine by turning the air-fuel mixture bolt all the way in then your pilot/low-speed jet is too big. Final adjustment should be made with a clean air filter mounted to the carburetor. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Erratic idle so confused Yamaha Star Forum
http://www.starbikeforums.com/forums/49-v-star/9084-v-star-acting-very-sluggish-sputtering.html
Yamaha XVS1300A 2007 Service Manual
YAMAHA XVS1300A Owner Manual
Dec 27, 2012 | 2009 Yamaha V Star 1300 Tourer
2003 Honda VT 750 C2 Shadow idle adjustment
Honda Shadow VT700C Running Lean Fix Pilot Jet Needle Shim Honda 1998 VT750C Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda VT750C Owner Manual
Aug 30, 2012 | 2003 Honda VT 750 C2 Shadow
Eclipse won't idle .
Throttle body, IAC or EGR valve.
Mar 12, 2017 | 2003 Mitsubishi Eclipse Coupe
Yamaha Ef600 Generator/inverter Repair/service Manual Logo
99 people viewed this question
Top Yamaha Electrical Supplies Experts
John Trevino
Robert Wooley
Robert Wooley
robert faass
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
