Question about Bosch Dishwashers
HOW DO i RESET A BOSCH DISHWASHER MODEL SHE56T55VC/02 THAT IS STUCK ON AUTO 2:02
Posted by mimito4 on
Sergio
    Habit-Forming:
    New Friend:
  • 143 Answers
From my side I would just go through this troubleshooting guide for Bosch Dishwashers: Common Bosch Dishwasher Problems And Solutions
Posted on May 31, 2019
Mark Cheong
    Master:
  • 791 Answers
First, I'm not a BOSCH tech.
I just installed an ELECTROLUX dishwasher last month and had a similar problem. We also have an older Kenmore dish washer in another part of the house. The Kenmore is at least 15 years old and the touch pads are very soft and easy to select. The new one did not select either. I have to firmly depress the pad (which seems to be a stiffer plastic) and make sure I'm pressing down on the right spot to get things to work.
* I recently came across the same problem. Pressing buttons won't change the displayed setting and it seemed to be 'stuck' in one mode but I coudn't tell if it was in between a cycle or just stuck. I've found that holding the 'start' button down (firmly) for 10 seconds will cancel all functions and it went back to normal. Since then it gets stuck several times over the week. I don't know if one of the kids is opening it up as I only turn it on at night just before going to sleep. So, someone may be sneaking around for a mid nite kitchen raid.
* If you still have problems then check your warranty as many of these machines have parts warranty for 3-5 years. The 'switch' section if bad must be completely replaced as it is all one piece. These membrane switches will get damaged from a sharp fingernail or using a knife or fork to force the button down. (happened with the Kenmore, Kids kept stabbing it to get it to turn on.)
Aloha, ukeboy57
Posted on Jun 06, 2018
5 Related Answers
benham
  • 125 Answers
SOURCE: Bosch dishwasher stuck on "1"
YOU MAY NEED A CONTROL BOARD OR A HEATER. THERE IS A CONNECTOR WITH A RED AND GRAY WIRE, THE RED WIRE IS THICKER THAN THE OTHER RED WIRES. IF YOU HAVE 120 VOLTS ON THERED WIRE THE CONTROL IS GOOD. YOU NEED A CLAMP ON AMP METER TO TEST TO SEE IF THERE IS AN AMP DRAW ON THE RED WIRE WHICH WOULD TELL YOU THE HEATER IS WORKING
Posted on Feb 07, 2008
douglas smith
  • 1462 Answers
SOURCE: Bosch dishwasher is stuck on drain cycle
cause is water in the bottom tray which operates an anti-flood switch and all machine will do is drain.
disconnect from mains
remove bottom panel and mop out water and it will work. if fault re-occurs, then you have a leak which you will have to identify
Posted on Oct 20, 2008
Lollo Pop
  • 134 Answers
SOURCE: reset model smu7052uc
there is none- if the program is mucked up-- pull the plug for 5 minutes
Posted on Jul 16, 2009
AZEBO .
  • 228 Answers
SOURCE: Bosch Dishwasher Maxx classixx Model S9H1B
look carefully at operating buttons they will have 2 marked with a line with dots at either end, open door press and hold these 2 buttons usually 2 and 4 as from left too right, turn on keeping fingers on these buttons after a few seconds end light will come on turn off at main switch then back on again should work after that.
Posted on Dec 15, 2009
bosch guru
  • 457 Answers
SOURCE: Bosch Classixx Dishwasher stck in one program
the module must be changed. let me know what happens. im a old bosch tech
Posted on Feb 26, 2010
Bosch SHU9915UC won't start. all lights come on but unit doesnt start. is there a reset button somewhere in this unit?
Reset the dishwasher by pressing and holding the "Start" button for at least three seconds. Depending upon the Bosch dishwasher model you have, you also can push the "Cancel-Reset" button to reset the dishwasher. Select a new cycle and press "Start."
Jan 03, 2018 | Bosch Dishwashers
I have a Bosch dishwasher SHX68T52UC/02 that has stopped working.
Hello!
Here you can find manuals to a huge range of Bosch dishwashers.
Hope you find a solution.
https://manualsbrain.com/en/brands/bosch/dishwashers
Aug 31, 2017 | Bosch Dishwashers
Opened dishwasher just as it filled up to put in another glass, now the dishwasher won't wash or drain. Power button won't cut off or reset cycles. Turned off breaker, but still stuck on same cycles
You don't mention what make/model of dishwasher. Some diswashers, like my Bosch, require a reset procedure to "kill" a cycle that you've already started. They don't like to have the power button pressed during the cycle. The procedure to reset varies by make and model. If you have the owner's manual, you may check in there for the procedure.
Oct 15, 2016 | Dishwashers
Bosch Model SHX68T55UC/02: Display says "watertap" and will not continue to run. There is water standing in the bottom of the machine. What should I do?
The machine is telling you to check the water supply which fills your dishwasher. Check if the water pipe is frozen or blocked, do you need to turn on a tap to allow the water go flow to the dishwasher ? :)
May 25, 2014 | Bosch Dishwashers
I need a manual fo a Bosch Dishwasher ~ SGS44E28EU
I think their may be an additional number after the model you wrote down ( looks like this perhaps SGS44E28EU/01 or /02 etc)
go to this page on the bosch website
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
find the appropriate download for your machine and save them to your desktop
Mar 18, 2010 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Bosch Dishwasher Maxx classixx Model S9H1B Lights stuck on end and last program.... will not reset nor start Think it just needs resetting ...but how?? Was working fine up to now Regards M
Nov 10, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Can't close Bosch Dishwasher door
I had same problem and was alarmed at the idea of taking the door apart, so I tried the 2 screwdriver option described below - it works!
Open door and get two small screwdirvers behind each side of the catch inside the top of the door and gently apply pressure. The catch should reset itself on 'open' and allow you to shut the door again.
Thanks to all for their postings and helpful advice!
Nov 10, 2007 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Dishwashers Logo
2,987 people viewed this question
Top Bosch Dishwashers Experts
Michael Thomas
Michael Thomas
peter gittos
peter gittos
Marvin
Marvin
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
